EReese3's avatar
EReese3
Follower
Apr 04, 2022
Status:
Comments Requested
Need a new INsight business router faster than 1GB (min 10) with fiber ports and all the VPN option
Need a replacement for the BR200 and BR500 and quickly!
one location is maxed out on 1gb fiber and would like to go faster and have the site to site function actually work as orginaly advertised for the BR500.  Also need the LAN ports to be be fiber
1 Comment
  • hnagaraju's avatar
    hnagaraju
    NETGEAR Employee Retired
    Status changed:
    New Idea
    to
    Comments Requested
    SXR80/SXR50/SXR30  are  Business routers.
    If  you WAC500/WAX600 series AP for wireless, Then just use SXR80 as wired Business router.
    You can disable Wireless.
    If you do not have WAX600 AP, then you can buy extra satellites and use them for whole office Wi-Fi coverage too.
    SXR80  has 2.5Gbps WAN port. It can do 5 DHCP pools,  It can handle up-to 512 DHCP IP address in each pool.
    The 4 LAN wired ports can be put into Access mode/Trunk Mode and PVID configured.
    For VPN, Branch2Branch we support Business VPN.  It is better than older Instant VPN.
    The main difference is BR500 was rack mount, But SXR80 is desktop, but can be installed  on top of rack.
