jmchez
Mar 16, 2017Tutor
Status:
New Idea
Next Orbi Firmware must allow guests to see each other but not access Lan
The Orbi Guest Network settings has checkbox option for, "Allow guests to see each other and access my local network". These TWO options must be separated as other routers do. Others before me have pointed out how having these two options treated as one is a security flaw, and defeats the whole point of having a GUEST network.
Guests may want to play games with other, use their wireless printer or connect their phones to Chromecast. They should be be able to do this without having access to the entire main network.
I hope that the next firmware remedies this.
11 Comments
Comments have been turned off for this idea
Actually you might check out Orbi Pro versions of NG MESH. Most low end or home class systems like Orbi (non Pro) and MK systems do not support any VLAN Tagging on SSIDs. Most home users don't have a need for SSID VLAN Tagging. It's recommended that users first research and do there due diligence in to a prospective wifi system before buying something.
- dohabanditAspirant
MR60 / MS60 should allow SSID to VLAN tagging for different SSID's, guest network, etc in AP mode.
- doug_schmidtFollower
I agree, this funtionality needs to be functional. A guest network is just that "a guest network". I do not want my guests
to access the main r6400v2 wifi or wired networks. A guest wifi network should be separate. An example of what I'm
looking to do, have my guest 5g network which will have google chromecast and my mobile cell phone on it. These two
devices need to be able to talk to each other. (mobile cell is the controller for chromecast).
Seems like what needs to happen is the check mark for "Allow guests to see each other and access my local network" needs
to be 2 separate options, 1 for "Allow guests to see each other" and 1 for "Just Internet Access". And maybe another for
"Access to local network", these options should be selectable/unselectable individually.
Another way to think about it, a home network that has devices that do not need access to the entire "home" network.
Think of smart devices (they really only need internet access) (TV, streaming devices, etc.) With these devices being
easily hackable, it would be best to have them isolated and have further configuration of the access they have to the
internet and local networks.
- ZofoorAspirant
I also agree with this. Currenty I have another old wifi device to manage guests becouse I would like to give them access to Internet and allow them to connect each other, but not to access my private lan.
I think there should be two options instead of one: one to allow them to communicate each other, and another to give them access to the private lan.
In that way we can manage the guest network as we need.
- JasonNNETGEAR Employee Retired
Hi Everyone,
Thank you for your suggestion on the new features. The ideas will be reviewed for consideration. :]
- Jason N
- hwhitFledgling
I just bought a new Nighthawk AC2300 (R7000P) and am extremely disappointed and angry that this brand new, high-priced router, does not separate the options to let Guests see each other, and to let Guests see my Main network. For 5 years I've happily used a Netgear WNDR3700 which had separate options to enable Wireless Isolation (guests can/can't see either other) and Access My Local Network (guests can/can't see Main devices). I used the Guest network for my kids and their friends--I trust them enough to use wifi and see each other (many multiplayer games require it), but I do not trust them (or their virus-prone devices) enough to see my work and home computers and shared folders. After 5 years I expected new and improved features, but Netgear has taken a step backward.
I am considering returning my new router to the store and buying a different (better) brand.
Needless to say, I will no longer be recommending Netgear to friends, and I'll have to explain why.
- Lefty_HDNovice
I completely agree, and better then that this guest network needs to be into another subnet with firewall rules between both networks to gives them the possibility to access few specific device/service inside the internal network if someone desire this functionality.
- NETGEAR_TeamCommunity ManagerStatus changed:New IdeatoNew Idea
- NETGEAR_TeamCommunity ManagerStatus changed:UnspecifiedtoNew Idea
- jmchezTutor
Yes.
The second checkbox would be, as is now, for wireless devices o the Guest network to be allowed to see devices n the Main network. I doubt that i would ever use this but some others might.
