Reply
Outdoor access point
I am looking to provide better wifi on my deck. I have a wired network from a ATT Remote Gateway (1 Gig) to a Netgear unmanaged switch. I have CAT 6 to an LG TV, Netgear WAX 620 and a couple of jacks. This all works. I am looking to run CAT 6 to my deck. Does Netgear make a small access point I can plug into the wall outside (under the eaves and GFCI outlet) and connect to CAT 6? Maybe the Powerline? I know I can use many of Netgears products. I am trying to eliminate the power supply cord and large device. This would help with wireless connections to my cameras on the deck and surfing.
Thank you
Message 1 of 11
Accepted Solutions
schumaku
Guru
Re: Outdoor access point
Alternate to an expensive power installation with GFCI, connector boxes and space for huge power bricks, consider a PoE+ or PoE++ wireless access point on a CAT6 or better cabling.
Cumbersome is that enclosures for wireless AP are not inexpensive.
Message 3 of 11
All Replies
Guru
Why not look for an outdoor rated POE powered access point like the WAX610y?
Message 2 of 11
schumaku
Guru
Message 3 of 11
Thank you. This is what I was looking for. it will be under the eves but still exposed. I will check into this one.
Harmon
Message 4 of 11
The GFCI is already there. I was just planning to run CAT 6 to it and plug in an Access Point/POE. Is there a particular model Netgear makes to satisfy this? I see the other response above.
Thanks
Harmon
Message 5 of 11
The POE + is the way to go as you both suggested. Thank you for your help. Single Cat 6 and no power supply or GFCI needed. Just need to figure out which one now I know this sort of beast exists.
Harmon
Message 6 of 11
I bought the NetGear Wireless Outdoor Access Point (WAX610Y) per everyone's input. Will run a length of CAT 6 and fire it up once it arrives.
Thanks!
Lynwood (Harmon) Hodge
Message 7 of 11
Guru
hope it works great!
Message 8 of 11
I ran CAT6 and cable checked out with tester. No lights on the NetGear WAX 610Y. The issue is with my NetGear GS116NA Switch. It does not support POE+. No where in the online manual is any indication of POE for this switch. Oh well. I am learning as I go. I will look for another NetGear Switch supporting POE+.
The setup looks nice though.
Harmon
Message 9 of 11
Guru
POE switches are a bit spending. If thats your only POE device, a poe injector might be a better purchase.
Message 10 of 11
I picked up an injector. It took a little bit on the NetGear side but it os working now. I picked up a 60W BV-Tech. I was looking for a NetGear Injector but did not see one. I will return the unopened 16 port POE switch to Amazon. $40 vs $200. Thank you for the information. I came close to sending the injector back but my current switch is less than six months old.
Harmon
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 2324 views
  • 6 kudos
  • 3 in conversation
Announcements
