cquint's avatar
cquint
WAX610 Slow
I have a WAX610 AP connected to GS108 Switch Connected to Netgate pfsense firewall. The wireless is extremly slow compared to the previous consumer Asus Router I was using. I have a 500mb connection I get about 450-550 when I run a speedtest on a computer with a cat cable connection. I get about 150-250mb when I run a speedtest on a wireless client. The wireless vlans are tagged on the switch. I have 2 SSID on seperate vlans that have internet access. The management vlan is untagged and doesnt have internet access with firewall rules blocking management vlan to internet.
  • schumaku's avatar
    schumaku
    What Chanel width is configured for the 5 GHz band? Probably less than the max available 80 MHz - this is the typical limiting factor, leaving the wireless client capabilities alone.
    This would prohibit the Insight management, and not allow using the WAX-hosted diagnostics troubleshoot and Ookla speed test-
  • It is on 40Mhz, I have tried to used 80Mhz. It didnt seem to have a significant difference.
    • schumaku's avatar
      schumaku
      The WAX610 is a AX1800 device, with AX1200 2x2 on 5 GHz, and AX600 2x2 on 2.4 GHz, permitting the full 80 MHz are available, and no competitive concurrent bandwidth usage on-air.
      Consult duckware 's great composition of WiFi insights on https://www.duckware.com/  FMI.
ProSupport for Business
