Orbi WiFi 7 RBE973
Reply
AC1750 WiFi Cable Modem Router (C6300v2)
Scott5485
I have Spectrun. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a speed check...148 mbps. Any idea whats going on with system?
Message 1 of 25
Kitsap
Master
Re: AC1750 WiFi Cable Modem Router (C6300v2)
What device are you using to check your throughput?  Laptop, desktop, phone, etc.?
How is it connected to your C6300v2, via Wi-Fi or via Ethernet?
What application are you using to check your throughput?  Recommend the stand alone installable application from Ookla, it is available free in the play store for all devices.
Normally your device would be discussed in the cable modem community here:
https://community.netgear.com/t5/Cable-Modems-Gateways/bd-p/home-cable-modems-routers
A moderator may move this discussion.
Message 2 of 25
Scott5485
I'm using a desktop to check. It is hardwired to modem/router. I used spectrum speed check to verify speed.
Message 3 of 25
Scott5485
I have Spectrum. Tech was here today and checked network. His speed check was 330 mbps before router. Speed check with computer was 250. Is there an issue with netgear? Is there a fix? I just did a speed check...148 mbps. Any idea whats going on with system?
Message 4 of 25
Kitsap
Master
What operating system are you running on your desktop computer?
Have you checked to see if your drivers for the Ethernet port are up to date?
Make sure you have good quality Ethernet cable between your computer and your R6300v2.
For consistency, you need to install the Ookla stand alone application for throughput testing.  It does not use a web browser to get in the way.
Message 5 of 25
Scott5485
Can open app. Say no wi-fi. I go to play and download app as instructed. Say can't connect to app. No wi-fi. I'm download app via wi-fi. Any ideas. Trying to update software.
Message 6 of 25
Kitsap
Master
Difficult to decipher and I do not understand what you are trying to say.  Complete sentences please.
Above statement is inconsistent with your statement about using a desktop computer hardwired to your router.
Message 7 of 25
Scott5485
Can't open app. Says no wi-fi. I go to play and download app as instructed. Says can't connect to app. No wi-fi. I'm download app via wi-fi. Any ideas. Trying to update software. Please review attached screen shot attached.
Message 8 of 25
Kitsap
Master
Close the mobile application.  It will not do you any good without Wi-Fi.
Start troubleshooting by looking at the LED indicators on the front of your C6300v2.  If you go to the top of this page to the Downloads section, put in your model number and download the user manual.  Starting on page 100 of the manual is a section on Troubleshooting With the LEDs.  There are several indicators that pertain to the Wi-Fi.  Which LEDs are lit and which are not?  Maybe you have accidentally turned the Wi-Fi off with the manual switch?
Can you connect to the router with your desktop computer?  With no Wi-Fi, you will have to use an Ethernet cable between the computer and the router.
Message 9 of 25
Scott5485
I have wifi. All other wifi connected devices work fine. App will not connect to netgear.
Message 10 of 25
Kitsap
Master
Check the firmware version on your C6300v2.  It requires version 1.03.06 for Nighthawk mobile application support.
Reference:  https://kb.netgear.com/000055505/Which-products-support-the-NETGEAR-Nighthawk-app
It appears the latest Spectrum approved firmware is version 1.02.09.
Reference:  https://kb.netgear.com/000036375/What-is-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-mo...
At this time, you cannot get there from here.  Future updates to either the Nighthawk application or the Spectrum approved firmware may resolve this problem.
Message 11 of 25
Scott5485
App connected previously. ?App supported.
Message 12 of 25
Scott5485
Desktop is hardwired to nighthawk. How do I access nighthawk?
Message 13 of 25
Scott5485
192.168.1.1 will not connect thru firefox or bing?
Message 14 of 25
Kitsap
Master
You might try routerlogin.net or 10.0.0.1.  Will not connect is very sparse on information.  What specific error message do you get?
Make sure you are using http:// and NOT https://.   Some browsers automatically default to https://.
Message 15 of 25
Kitsap
Master
Completely uninstall the mobile application and all of the data associated with it.
Reinstall and configure the mobile application from scratch.
Have you registered your router at netgear.com with a MyNETGEAR account?
Message 16 of 25
Scott5485
Yes,registered. Out of warranty.
Message 17 of 25
Scott5485
Reinstalled and still will not connect. Problem loading logon page. Again, when I try to connect it says to connect wifi. Wifi is connected on phone.
Message 18 of 25
Kitsap
Master
Warranty does not have anything to do with the question.  When you sign in to your MyNETGEAR account, your C6300v2 should show up on your products list.  Usually the Nighthawk application asks you for your MyNETGEAR account user name and password during install.
Message 19 of 25
Kitsap
Master
What version of the Nighthawk application do you have installed?
I am using version 2.27.1.3003 for Android.
Are you using an iPhone?
Message 20 of 25
Scott5485
I had to sign-in when I reloaded app?
Message 21 of 25
Scott5485
2.27.1.3003
Message 22 of 25
Kitsap
Master
I am at the end of my options.  On paper the Nighthawk application does not support the firmware version you have installed on your C6300v2.  Yet you say you have had it working in the past.
Message 23 of 25
Scott5485
I now in Netgear genie. Don't see a way to update firmware. Am I missing something?
Message 24 of 25
Kitsap
Master
No.  Firmware updates on your C6300v2 are the exclusive territory of your ISP (Spectrum).
Some of the newer combination modem/router devices have separate firmware packages for both the modem and the router.  The modem can only be updated by the ISP and the router can be updated by the end user.
Message 25 of 25
Top Contributors
Discussion stats
  • 24 replies
  • 2862 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
