Orbi WiFi 7 RBE973
Reply
C6230 requiring reboots during large file tranfers
Ethan69420
Initiate
since buying this modem new it always loses connection to the internet during large downloads.
its finally bothering me enough to reach out.
ISP: Optimum
event log.
Message 1 of 4
Guru
Re: C6230 requiring reboots during large file tranfers
Sadly thats just the standard bootup log. It clears on reboot for most devices.
Do you have a screensnip of the cable connections page?
also, have you noticed if it happens when done over wifi versus wired?
And 2.4ghz vs 5ghz?
Message 2 of 4
Ethan69420
Initiate
Seems to happen wired or wireless but I normally use the 5ghz connection.
Message 3 of 4
Guru
Wow your signal is coming in hot. It should be between -7.5dbmv and 7.5dbmv. You're over 15.
You need a signal attenuator in line. That hot of a line would cause reboots easily.
Message 4 of 4
Discussion stats
  • 3 replies
  • 473 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
