Orbi WiFi 7 RBE973
Reply
C6300 only solid Green power light
jdf1984
Tutor
Hello, I woke up this morning with my C6300 only having a solid Green power light on. I’ve tried power cycling it a number of times, but the same thing happens. I can’t even log into the router to troubleshoot. Anyone have an idea about how to correct this?
Model: C6300|AC1750 Cable Modem Router Docsis 3.0
Message 1 of 6
Guru
Re: C6300 only solid Green power light
did you try a factory reset? Push and hold reset for 7-15 seconds while powered on
Message 2 of 6
jdf1984
Tutor
I attempted a factory reset, but nothing changed. The power light never changed, and no other lights came on
Message 3 of 6
Guru
did you try it with the coax disconnected?
And hold reset for up to 30 seconds?
Message 4 of 6
jdf1984
Tutor
Just tried that as well, no change
Message 5 of 6
Guru
are you able to hardwire into it and ping it at 192.168.100.1 at all?
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 1172 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
