- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
C7000v2 Keeps Resetting
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been experiencing this issue for months now that randomly, there's no fixed time when this happens could be 10pm could be 6am. My C7000v2 router will reset. It won't lose power, but almost all the lights on the front go compeltely yellow for a few seconds then turn off, the power light remains on and green, but router then spends a couple minutes rebooting and after a couple minutes the internet comes back as normal. It can do this anywhere from 1 to 6 or 7 times a day. I've reseated the power, ethernet, and coax cables on both ends of the device and the other ends, making sure everything is fully plugged in and there's no rips or bends in any of the cables. I've tried powercycle the device, I've factory reset the device. I've done an ipconfig /release and ipconfig /renew and nothing resolves the issue. I've consutlted Xfinity support on the issue and they can't recommend anything I haven't tried
I can't afford another router and desperately need to get this fixed.
I can provide any more information needed
C7000v2
Firmware Version 1.03.03
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: C7000v2 Keeps Resetting
Log into the device a take a screen snip of the event log and the cable connections page.
Those can tell us if there's line issues causing it or if the reset signal is being sent by the ISP or CMTS.
- Mark as New
- Bookmark
- Subscribe
- Permalink
NOTE: REMOVED CMAC AND MAC FOR PRIVACY
UPSTREAM/DOWNSTREAM
Startup Procedure | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
EVENT LOG
- Mark as New
- Bookmark
- Subscribe
- Permalink
You must have just rebooted it. Try it after its ran for a while or after it does a reboot cycle
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router was working mostly fine today until a few minutes ago. I pulled this from Event logs just now
1970-1-1, 00:00:49 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
1970-1-1, 00:00:40 | Notice (6) | WiFi Interface [wl1] set to Channel 128 (Side-Band Channel:N/A) - Reason:INIT |
1970-1-1, 00:00:40 | Notice (6) | WiFi Interface [wl0] set to Channel 4 (Side-Band Channel:N/A) - Reason:INIT |
1970-1-1, 00:00:39 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; |
1970-1-1, 00:00:37 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing; |
1970-1-1, 00:00:38 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;; |
1970-1-1, 00:00:39 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Seems like your logs are clearing out in the reboot. that makes it more of a challenge because now we're just guessing.
1 thing you can try is if you have a seperate power supply sitting around that has the same voltage and polarity and AT LEAST the same amperage rating (it can have more but not less), try that. Maybe the power supply is going out and failing under load/heat.
