Orbi WiFi 7 RBE973
Reply
C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router MoCA
tonytampa
Follower
Hi,
Does anyone know if the C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router is MoCA compatible?  I am trying to run Wired connection to 2 different floors in my house using the existing Coax Cable Network.  I am not sure if I will need 2 MoCA Adapters, 1 for the Modem/Router and the other for the second room, or if the Nighthawk is already MoCA Complatible where I will just need 1 in the other room to pull through a wired ethernet connection.
If anyone knows of a better way to run a wired connection without having to run ethernet wiring through the whole house please help!
Model: C7000|Nighthawk - AC1900 WiFi Cable Modem Router
Message 1 of 2
Accepted Solutions
Guru
Re: C7000v2 – Nighthawk AC1900 WiFi Cable Modem Router MoCA
the C7000 doesn't have moca capabilities built into it.
Message 2 of 2
All Replies
Guru
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 5715 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
