Orbi WiFi 7 RBE973
Reply
C7000v2 connects but no internet
xx2pro4uxx21
I just got wifi today but I'm running into a problem where my PC connects to the wifi and it says that I have internet access but I'm still not able to connect to the internet. From what I've found online, the wan light is on but isn't blinking. So I've turned everything off and followed the process with that with no change. I downloaded the Ethernet driver for my PC and I was able to get the Ethernet to connect now but same problem with not having any internet. All of the lights are green and a couple of them blink a little bit but not the wan light.
Message 1 of 17
Accepted Solutions
xx2pro4uxx21
Re: C7000v2 connects but no internet
Huh it's working all of a sudden.
Message 10 of 17
All Replies
Guru
do you mean the internet LED? The C7000v2 doesn't have a wan port.
do you have a screen snip of the cable connections page and the event logs from the modem? Helps check the connection.
https://www.netgear.com/support/product/c7000v2
Message 2 of 17
xx2pro4uxx21
Alright here's some pictures of everything I could find that might help.
Message 3 of 17
xx2pro4uxx21
Message 4 of 17
xx2pro4uxx21
Message 5 of 17
xx2pro4uxx21
Message 6 of 17
Guru
xx2pro4uxx21
And there's the cable connections page
Message 8 of 17
Guru
You missed out on some channels. Scroll down a bit.
But from the initial, you're not getting all your channels locked.
Try removing any splitters or signal attenuators from your line.
Check for kinks, damage, loose/old/bad/corroded coax cables and remove them if you do
Message 9 of 17
xx2pro4uxx21
Message 10 of 17
Telepathy.
@plemans can perform all manner of magic by remote control.
Message 11 of 17
xx2pro4uxx21
Oh ok lol. Well thank you Netgear God plemans for fixing it if it was you.
Message 12 of 17
Guru
Please mark your thread as solved so others will know.
Enjoy.
Message 13 of 17
Not easy when you don't know how it was solved.
But without some details on what actually happened, not much that anyone else can follow, beyond invoking @plemans
But what the heck? Fixed.
Message 14 of 17
Guru
The fix is always @plemans Smiley Very Happy
Message 15 of 17
Guru
If only my wife thought that we'd be good. 😀
Message 16 of 17
Guru
Smiley LOL
Message 17 of 17
Top Contributors
Discussion stats
  • 16 replies
  • 8614 views
  • 2 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
