Orbi WiFi 7 RBE973
Reply
CG2000-1TDNDS How do I set up?
OlaWetterling
How do I set up and get connected? Is there a manual to download?
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: CG2000-1TDNDS How do I set up?
Hello Olawetterling
Are you talking about the CG3000? did you but this modem or get it from your ISP?
DarrenM
Message 2 of 4
OlaWetterling
Thanks for your reply, Darren!
I've got it from my internet provider (yousee, Denmark). For use with thei cable network in the building. Used coax connection. Is that's why? And would it work if I reste the router to "factory mode"? And then - how do I set it up?....
Message 3 of 4
DarrenM
Hello OlaWetterling
Yea you could try to factory reset the unit by holding the the reset button for 10 seconds. But you may need to contact your ISP.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2835 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
