Orbi WiFi 7 RBE973
Reply
CM1000v2 MDD Message Timeout
jmzpeaches
Follower
I have been having intermittent connectivity issues with my modem. I recently moved and am using my own modem and router, but nearly every day I have had the internet go down at least once for about a minute before coming back on its own. I called my ISP and after they tried troubleshooting over the phone, they sent a tech out to check the connections and everything. They didn't find any obvious problems so after the issues kept happening, I tried called Netgear support. I ended up replacing the modem in case there were hardware issues with the first one. After the problems kept occurring, I did some more digging and found the error messages in the event log of my modem. I wish I did that first, but what's done is done.
I searched the forum for other people that had issues, but the solutions offered in other threads were looked to be geared toward the specific problems of that user. I have copied below the event log showing the details of my problems as well as my cable connection settings. Any help troubleshooting would be much appreciated.
TimePriorityDescription
2022-03-13, 20:32:38Warning (5)Dynamic Range Window violation
2022-03-13, 20:32:38Warning (5)RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=6c:cd:d6:99:55:44;CMTS-MAC=f8:7b:20:51:01:5b;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 20:32:33Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 3.;CM-MAC=6c:cd:d6:99:55:44;CMTS-MAC=f8:7b:20:51:01:5b;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 20:32:32Notice (6)TLV-11 - unrecognized OID;CM-MAC=6c:cd:d6:99:55:44;CMTS-MAC=f8:7b:20:51:01:5b;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 20:32:31Warning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=6c:cd:d6:99:55:44;CMTS-MAC=f8:7b:20:51:01:5b;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 20:32:28Notice (6)Honoring MDD; IP provisioning mode = IPv4
2022-03-13, 20:31:39Notice (6)CM-STATUS message sent. Event Type Code: 1; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=6c:cd:d6:99:55:44;CMTS-MAC=f8:7b:20:51:01:5b;CM-QOS=1.1;CM-VER=3.1;
2022-03-13, 20:31:38Warning (5)
MDD message timeout;CM-MAC=6c:cd:d6:99:55:44;CMTS-MAC=f8:7b:20:51:01:5b;CM-QOS=1.1;CM-VER=3.1;
<tabindex=-1>Startup Procedure</tabindex=-1>
ProcedureStatusComment
Acquire Downstream Channel699000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnableBPI+
IP Provisioning ModeHonor MDDIPv4 only
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1LockedQAM25632699000000 Hz6.3 dBmV41.7 dB276080357600
2LockedQAM2561495000000 Hz4.4 dBmV42.2 dB275694718900
3LockedQAM2562501000000 Hz4.9 dBmV42.2 dB275695327000
4LockedQAM2563507000000 Hz4.6 dBmV42.0 dB275696015100
5LockedQAM2564513000000 Hz4.8 dBmV42.1 dB275696542000
6LockedQAM2565519000000 Hz4.1 dBmV41.7 dB275697259400
7LockedQAM2566525000000 Hz4.6 dBmV41.9 dB275697953800
8LockedQAM2567531000000 Hz4.1 dBmV41.7 dB275698684020
9LockedQAM2568537000000 Hz4.1 dBmV41.7 dB275699236000
10LockedQAM2569543000000 Hz3.8 dBmV41.6 dB275699932900
11LockedQAM25610549000000 Hz3.9 dBmV41.5 dB275700987000
12LockedQAM25611555000000 Hz4.0 dBmV41.7 dB275701627500
13LockedQAM25612561000000 Hz4.2 dBmV41.8 dB275702248200
14LockedQAM25613567000000 Hz3.9 dBmV41.4 dB275702933800
15LockedQAM25614573000000 Hz4.1 dBmV41.5 dB275703540400
16LockedQAM25615579000000 Hz4.2 dBmV41.5 dB275704208200
17LockedQAM25616585000000 Hz4.2 dBmV41.6 dB275704922800
18LockedQAM25617591000000 Hz4.2 dBmV41.5 dB275705503100
19LockedQAM25618597000000 Hz4.2 dBmV41.5 dB275706126520
20LockedQAM25619603000000 Hz4.3 dBmV41.4 dB275706780410
21LockedQAM25620609000000 Hz3.8 dBmV41.3 dB275707896600
22LockedQAM25621615000000 Hz4.4 dBmV41.3 dB275708493800
23LockedQAM25622621000000 Hz3.9 dBmV41.3 dB275709225610
24LockedQAM25623627000000 Hz4.4 dBmV41.3 dB275709893300
25LockedQAM25624633000000 Hz3.9 dBmV41.1 dB275710497000
26LockedQAM25625657000000 Hz4.4 dBmV41.3 dB275711143200
27LockedQAM25626663000000 Hz5.2 dBmV41.6 dB275711809300
28LockedQAM25627669000000 Hz5.0 dBmV41.4 dB275712514800
29LockedQAM25628675000000 Hz5.5 dBmV41.1 dB275713157000
30LockedQAM25629681000000 Hz5.2 dBmV41.5 dB275713784700
31LockedQAM25630687000000 Hz5.8 dBmV41.7 dB275713507000
32LockedQAM25631693000000 Hz6.0 dBmV41.5 dB275712791100
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
1LockedATDMA116200000 Hz46.0 dBmV
2LockedATDMA222700000 Hz47.0 dBmV
3LockedATDMA329200000 Hz47.0 dBmV
4LockedATDMA435700000 Hz48.0 dBmV
5Not LockedUnknown00 Hz0.0 dBmV
6Not LockedUnknown00 Hz0.0 dBmV
7Not LockedUnknown00 Hz0.0 dBmV
8Not LockedUnknown00 Hz0.0 dBmV
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1Locked0, 1, 3159771000000 Hz7.8 dBmV34.5 dB646 ~ 344952624369253613616928
2Not Locked000 Hz0.7 dBmV0.0 dB0 ~ 4095000
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
1Not LockedUnknown00 Hz0 dBmV
2Not LockedUnknown00 Hz0 dBmV
Model: CM1000|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready
Message 1 of 2
Guru
Re: CM1000v2 MDD Message Timeout
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1484 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
