Orbi WiFi 7 RBE973
Reply
CM1200 Downstream light blinking and Cox wont help
jpwesterman
For a couple of weeks now we will get sudden drops during the day needing to restart the modem and router to gain service. Since then the downstream arrow has been blinking. I contacted Cox and of course, they blame it on the equipment that isn't theirs.  I'm seeing quite a few errors and included them below.
TimePriorityDescription
Mon Jan 23 16:06:21 2023Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 16:05:55 2023Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2 3.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 16:02:59 2023Notice (6)CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 16:02:34 2023Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 2 3.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:54:06 2023Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:50:19 2023Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:50:09 2023Notice (6)CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:50:09 2023Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:50:08 2023Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:49:01 2023Warning (5)Dynamic Range Window violation
Mon Jan 23 15:49:01 2023Warning (5)RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:49:00 2023Warning (5)Dynamic Range Window violation
Mon Jan 23 15:49:00 2023Warning (5)RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:48:59 2023Warning (5)REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:48:55 2023Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:48:50 2023Notice (6)TLV-11 - unrecognized OID;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:48:49 2023Warning (5)DHCP WARNING - Non-critical field invalid in response ;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedNotice (6)Honoring MDD; IP provisioning mode = IPv4
Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:47:32 2023Critical (3)Resetting the cable modem due to docsDevResetNow
Mon Jan 23 15:44:16 2023Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:19:45 2023Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:19:39 2023Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:19:35 2023Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:19:25 2023Notice (6)CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:19:25 2023Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:19:15 2023Notice (6)CM-STATUS message sent. Event Type Code: 20; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:19:15 2023Notice (6)CM-STATUS message sent. Event Type Code: 16; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0.;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:18:42 2023Critical (3)Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Mon Jan 23 15:18:34 2023Warning (5)Dynamic Range Window violation
Mon Jan 23 15:18:34 2023Warning (5)RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=6c:cd:d6:6b:b5:24;CMTS-MAC=b0:8b:d0:23:85:5d;CM-QOS=1.1;CM-VER=3.1;
Message 1 of 5
Guru
Re: CM1200 Downstream light blinking and Cox wont help
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
You have Criticals and Warnings the the ISP needs to review and help resolve from there side.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Message 2 of 5
Guru
Your log indicates line issues.
But its tough to tell without the cable connections page. Sometimes its to low of power and sometimes to high.
Or sometimes its just straight up issues.
If you can post that back here, it gives us a little direction to point you in.
In the mean time, you can start with removing any amplifiers, signal attenuators, or splitters from the coax.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
Message 3 of 5
jpwesterman
Hey, thanks for the quick response. Ill try that and see. Please find the cable connection below.
Startup Procedure
ProcedureStatusComment
Acquire Downstream Channel429000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnabledBPI+
IP Provisioning ModeHonor MDDhonorMdd(4)
Downstream Bonded Channels
ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectables
1LockedQAM25645429000000 Hz-1.4 dBmV44.1 dB47178
2LockedQAM2561675000000 Hz-0.6 dBmV43.1 dB2544
3LockedQAM2562681000000 Hz-0.9 dBmV44.1 dB1454
4LockedQAM2563687000000 Hz-1.2 dBmV43.9 dB2646
5LockedQAM2564693000000 Hz-1.9 dBmV43.5 dB2545
6LockedQAM2565699000000 Hz-2.4 dBmV43.1 dB1955
7LockedQAM2566705000000 Hz-2.7 dBmV42.9 dB5527
8LockedQAM2567711000000 Hz-2.7 dBmV42.9 dB2829
9LockedQAM2568717000000 Hz-2.3 dBmV43.1 dB3523
10LockedQAM2569723000000 Hz-1.9 dBmV43.4 dB3023
11LockedQAM25610729000000 Hz-1.6 dBmV43.5 dB3426
12LockedQAM25611735000000 Hz-1.4 dBmV43.6 dB2642
13LockedQAM25612741000000 Hz-1.4 dBmV43.5 dB1851
14LockedQAM25613747000000 Hz-1.5 dBmV43.4 dB2648
15LockedQAM25614753000000 Hz-1.6 dBmV43.4 dB2160
16LockedQAM25615759000000 Hz-1.6 dBmV43.4 dB1556
17LockedQAM25616765000000 Hz-1.8 dBmV43.3 dB16026
18LockedQAM25633357000000 Hz-0.3 dBmV44.6 dB3475
19LockedQAM25634363000000 Hz-0.4 dBmV44.6 dB2485
20LockedQAM25635369000000 Hz-0.6 dBmV44.5 dB26107
21LockedQAM25636375000000 Hz-0.6 dBmV44.5 dB31152
22LockedQAM25637381000000 Hz-0.6 dBmV44.5 dB49165
23LockedQAM25638387000000 Hz-0.6 dBmV44.5 dB35203
24LockedQAM25639393000000 Hz-0.6 dBmV44.5 dB40218
25LockedQAM25640399000000 Hz-0.6 dBmV44.5 dB33216
26LockedQAM25641405000000 Hz-0.6 dBmV44.5 dB44200
27LockedQAM25642411000000 Hz-0.7 dBmV44 dB67212
28LockedQAM25643417000000 Hz-1 dBmV44.4 dB63206
29LockedQAM25644423000000 Hz-1.2 dBmV44.2 dB71213
30LockedQAM25646435000000 Hz-1.5 dBmV44 dB77183
31LockedQAM25647441000000 Hz-1.8 dBmV44 dB17102
32LockedQAM25648447000000 Hz-1.8 dBmV44 dB153420
Upstream Bonded Channels
ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
1LockedATDMA15120 Ksym/sec17400000 Hz39 dBmV
2LockedATDMA25120 Ksym/sec23900000 Hz39.5 dBmV
3LockedATDMA35120 Ksym/sec30300000 Hz39.5 dBmV
4LockedATDMA45120 Ksym/sec36700000 Hz39.5 dBmV
5LockedATDMA55120 Ksym/sec60000000 Hz39.5 dBmV
6LockedATDMA65120 Ksym/sec67000000 Hz40 dBmV
7LockedATDMA75120 Ksym/sec74000000 Hz40.8 dBmV
8LockedATDMA85120 Ksym/sec81000000 Hz40.8 dBmV
Downstream OFDM Channels
ChannelLock
Status
Modulation /
Profile ID
Channel
ID
FrequencyPowerSNR /
MER
Active Subcarrier
Number Range
Unerrored
Codewords
Correctable
Codewords
Uncorrectable
Codewords
1Locked0 ,1 ,2 ,3159300000000 Hz0.4 dBmV44.9 dB2216 ~ 59751909698306234000733877
2Not Locked000 Hz0 dBmV0.0 dB0 ~ 4095000
Upstream OFDMA Channels
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPower
1Not Locked000 Hz0 dBmV
Message 4 of 5
Guru
You have Correctables and Un-correctables that should be mostly zeros.
Check all fittings and cable runs. Remove any splitters as suggested. Ensure coax jacks are snug and inplace well.
@jpwesterman
Message 5 of 5
Discussion stats
  • 4 replies
  • 1035 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
