- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM1200 Speed drops down to 12mbps reboot fixes it for a while
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all, I just bought this CM1200 and it was working fine but all of a sudden now after a while the connection drops to like 12mbps we are supposed to have gigablast (COX) service. If we reboot the modem we will get around 900mbps but after a while it goes back to 12mbps. Some more info is I had a motorolla surf modem before this that I had the same issue which I thought was the modem so I bought this CM1200 thinking it would fix the issue
I am not sure if the logs or settings will help but I will post them
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM1200 Speed drops down to 12mbps reboot fixes it for a while
Your power levels are border on a bit too high.
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Lots of correct and uncorrectables that should be zero.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem. Check for kinks and ensure fittings are correct and snug.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure and install the Ookla native operating system applications on your various devices for testing (phones, computers, tablets). The on board router applications are historically inconsistent.
The gradual decline of throughput on a re-booted coax system is usually an indication of problems with the system ground or poorly installed/corroded end fittings.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
