- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
CM500-100NAS help thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM500-100NAS help thanks
Start with just a decent quality double splitter. And go:
direct -----double splitter
modem
Test that to ensure its still good.
- Mark as New
- Bookmark
- Subscribe
- Permalink
any good one i should buy or brand i never bought splitter like thsi what one i want thanks?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
the pick up a 2 way splitter.
You want the modem getting the best possible signal you can get.
- Mark as New
- Bookmark
- Subscribe
- Permalink
had to go to walmart to get my mom some stuff while i was there i bought a 2 way slitter its a 5-2500mhz will follow what you posted post back once i can what need
- Mark as New
- Bookmark
- Subscribe
- Permalink
so modem on drect line right to outside and rest in splitter right?
- Mark as New
- Bookmark
- Subscribe
- Permalink
also i called tech support sed outige after ment i talked to from tech support herre what getting now
Frequency start Value | |
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
Startup Procedure
Procedure | Status | Comment |
Acquire Downstream Channel | 615000000 Hz | Locked |
Connectivity State | OK | Operational |
Boot State | OK | Operational |
Security | Enabled | BPI+ |
IP Provisioning Mode | Honor MDD | honorMdd(4) |
Downstream Bonded Channels
Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectables |
1 | Locked | QAM256 | 10 | 615000000 Hz | 4.8 dBmV | 42.2 dB | 0 | 0 |
2 | Locked | QAM256 | 1 | 561000000 Hz | 5.3 dBmV | 43.2 dB | 0 | 0 |
3 | Locked | QAM256 | 2 | 567000000 Hz | 5.5 dBmV | 43.2 dB | 0 | 0 |
4 | Locked | QAM256 | 3 | 573000000 Hz | 4.3 dBmV | 42.1 dB | 0 | 0 |
5 | Locked | QAM256 | 4 | 579000000 Hz | 4.1 dBmV | 41.8 dB | 0 | 0 |
6 | Locked | QAM256 | 5 | 585000000 Hz | 5 dBmV | 42.1 dB | 0 | 0 |
7 | Locked | QAM256 | 6 | 591000000 Hz | 4.3 dBmV | 41.9 dB | 0 | 0 |
8 | Locked | QAM256 | 7 | 597000000 Hz | 3.6 dBmV | 41.8 dB | 0 | 0 |
9 | Locked | QAM256 | 8 | 603000000 Hz | 3.4 dBmV | 41.9 dB | 0 | 0 |
10 | Locked | QAM256 | 11 | 621000000 Hz | 4.5 dBmV | 41.3 dB | 0 | 0 |
11 | Locked | QAM256 | 12 | 627000000 Hz | 4.4 dBmV | 38 dB | 0 | 0 |
12 | Locked | QAM256 | 15 | 645000000 Hz | 5.2 dBmV | 40.4 dB | 0 | 0 |
13 | Locked | QAM256 | 21 | 687000000 Hz | 8 dBmV | 43 dB | 0 | 0 |
14 | Locked | QAM256 | 22 | 693000000 Hz | 7.1 dBmV | 42.6 dB | 0 | 0 |
15 | Locked | QAM256 | 23 | 699000000 Hz | 6.8 dBmV | 42.8 dB | 0 | 0 |
16 | Locked | QAM256 | 27 | 723000000 Hz | 5.6 dBmV | 41.4 dB | 0 | 0 |
Upstream Bonded Channels
Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
1 | Locked | ATDMA | 2 | 5120 Ksym/sec | 24600000 Hz | 43 dBmV |
2 | Locked | ATDMA | 1 | 2560 Ksym/sec | 18000000 Hz | 43 dBmV |
3 | Locked | ATDMA | 3 | 5120 Ksym/sec | 31000000 Hz | 43.5 dBmV |
4 | Locked | ATDMA | 4 | 5120 Ksym/sec | 37400000 Hz | 43.5 dBmV |
Extended Upstream Transmit Power Enable Extended Upstream Transmit Power
Current System Time:Tue Mar 08 22:23:24 2022System Up Time:00:03:16
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Much better. No current errors.
Time, your logs, and if it stays stable will be the key.
- Mark as New
- Bookmark
- Subscribe
- Permalink
tryed your way lost tv and internet so when back to 3 way splitter i guess 2 lines are comming out of lock box on wall also, might of left way old people had it from comcast with new replaced lines and here what i getting after reboot
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Startup Procedure
1 | Locked | QAM256 | 10 | 615000000 Hz | 5.1 dBmV | 41.7 dB | 0 | 0 |
2 | Locked | QAM256 | 1 | 561000000 Hz | 5.9 dBmV | 43.1 dB | 0 | 0 |
3 | Locked | QAM256 | 2 | 567000000 Hz | 6 dBmV | 43 dB | 0 | 0 |
4 | Locked | QAM256 | 3 | 573000000 Hz | 4.8 dBmV | 41.9 dB | 0 | 0 |
5 | Locked | QAM256 | 4 | 579000000 Hz | 4.6 dBmV | 41.5 dB | 0 | 0 |
6 | Locked | QAM256 | 5 | 585000000 Hz | 5.5 dBmV | 41.9 dB | 0 | 0 |
7 | Locked | QAM256 | 6 | 591000000 Hz | 4.7 dBmV | 41.6 dB | 0 | 0 |
8 | Locked | QAM256 | 7 | 597000000 Hz | 4 dBmV | 41.5 dB | 0 | 0 |
9 | Locked | QAM256 | 8 | 603000000 Hz | 3.8 dBmV | 41.6 dB | 0 | 0 |
10 | Locked | QAM256 | 11 | 621000000 Hz | 4.7 dBmV | 41.3 dB | 0 | 0 |
11 | Locked | QAM256 | 12 | 627000000 Hz | 4.8 dBmV | 40 dB | 0 | 0 |
12 | Locked | QAM256 | 15 | 645000000 Hz | 5.6 dBmV | 39.2 dB | 0 | 0 |
13 | Locked | QAM256 | 21 | 687000000 Hz | 8.2 dBmV | 42.5 dB | 0 | 0 |
14 | Locked | QAM256 | 22 | 693000000 Hz | 7.1 dBmV | 41.9 dB | 0 | 0 |
15 | Locked | QAM256 | 23 | 699000000 Hz | 6.9 dBmV | 42.2 dB | 0 | 0 |
16 | Locked | QAM256 | 27 | 723000000 Hz | 5.9 dBmV | 41 dB | 0 | 0 |
2 | Locked | ATDMA | 1 | 2560 Ksym/sec | 18000000 Hz | 42.8 dBmV |
Current System Time:Tue Mar 08 23:07:22 2022System Up Time:00:47:14
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM500-100NAS
on 3/20/2022 i see this what is it tell isp about tek error i see thanks ray isp keep telling me to come to netgear for help
under event log
Time | Priority | Description |
2022-3-20, 16:43:58 | Warning (5) | TEK Invalid - Invalid Key Sequence Number;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
2022-3-20, 16:20:27 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
2022-3-15, 05:54:00 | Notice (6) | DHCP Renew - lease parameters UTC Time Offset modified;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
2022-3-13, 22:49:58 | Notice (6) | TLV-11 - unrecognized OID;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
1970-1-1, 00:00:32 | Notice (6) | Honoring MDD; IP provisioning mode = IPv4 |
1970-1-1, 00:00:27 | Critical (3) | No Ranging Response received - T3 time-out;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.0;CM-VER=3.0; |
1970-1-1, 00:00:21 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
2022-3-13, 17:40:39 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
2022-3-13, 17:40:04 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
2022-3-13, 17:39:59 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
2022-3-13, 15:37:05 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
2022-3-13, 15:37:00 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
1970-1-1, 00:00:22 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.0;CM-VER=3.0; |
2022-3-12, 20:12:00 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
2022-3-12, 20:11:32 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
2022-3-12, 20:11:31 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire FEC framing;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
2022-3-12, 20:11:25 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
2022-3-12, 20:11:20 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=94:a6:7e:bb:f7:04;CMTS-MAC=00:01:5c:69:fc:4d;CM-QOS=1.1;CM-VER=3.0; |
- « Previous
- 1
- 2
- Next »
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
