Orbi WiFi 7 RBE973
Reply
CM500 no connection
U230148
CM500 no connection
I bought a CM500-100NAS from a neighbor to have as a spare, and it only locks into one downstream channel at very low power, -26 dBmV, and no lock on any upstream channel.
I have two other modems that have been connecting OK for several years, though we lose internet in the neighborhood several times a day for a few minutes each.
The neighbor said it worked for him but he doesn't need it anymore.  He agreed to take it back if I had any problems.  I suspect it's bad but I'd like to get some confirmation before returning it.
I've attached the channel status, I'll follown up with the error log and channel status of my known good modem.
Message 1 of 10
U230148
Re: CM500 no connection
Here's the error log of the CM500
Message 2 of 10
U230148
Here's the connection status of the known good modem
Message 3 of 10
Guru
try changing coax cables. Also, check any splitters,amplifiers, or signal attenuators. remove them if you have th em.
Your correct in that either something is dropping the power or its bad.
The connection info from the known good ones might help. Plus it might tell us why its dropping daily.
Message 4 of 10
Guru
power levels look good on the motorola but it hasn't been running long enough to give us logs/errors of much use.
the logs on the cm500 are indicating low power. Again, I'd try a different cable. If the downstream power really is that low, you'd have a much higher upstream value as it'd have to boost its power to communicate with the cmts.
So check the cables to see if theres one thats kinked, damaged, loose, correded, etc.
Message 5 of 10
U230148
I ran a homerun RG6 from the outside interface to my modem last year when we kept getting the daily drops.  It did not help.  There is nothing between the interface and the modem except new RG6.
I saw an Xfinity truck in the neighborhood earlier this year, and I chased him down to ask him about the service issues.  He was well aware of problems in the neighborhood and was there to troubleshoot.  Things are  better since then but we still have several short drops everyday.  Calling support is of little use because they require you to reboot the modem before they will help, and typically by then the drop has ended.
Message 6 of 10
Guru
Try it back at the neighbors house you got it from. See if the signal is bad there as well.
Message 7 of 10
U230148
After 1.5 hours the Motorola modem has accumulated 61 corrected errors, no uncorrected errors. Error log is still clear.
In the past I've connected the modems directly to the outside Xfinity interface, and we still had the short drops in service. That's convinced me that the problems are Xfinity's and not mine.
I'll try connecting the CM500 to the Xfinity interface, and if there's no improvement I'll conclude it's defective. Is there any other reason to have good signal levels on two modems and nearly no signal on a third?
Message 8 of 10
Guru
no.
if there's 2 good ones. its probably a hardware failure.
I'd be betting on the coax connection in the modem
Message 9 of 10
U230148
Thanks for the replies, I appreciate you taking the time to help out.
I don't think the previous owner has an active cable connection anymore to try it over there.
I may open up the modem and see if there's anything obviously wrong with the cable connector.
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1390 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
