- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
CM700 modem low download speed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Our ISP is claiming that our house is receiving the full 600 mbps speed, so they say it has to be our modem or router slowing things down. Our speed test show only 140 mbps on the 5.0 and 40 mbps on the 2.4 The modem says it can get up to 1.4 Gbps. Is there anything I can do in order to get the right speeds to my devices?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: CM700 modem low download speed
The CM modem doesn't have a built in router or wifi.
What are your wired speecs with a PC or laptop connected to the CM modem and not thru a router?
The CM modem is well capable of doing near 900Mpbs on wired speeds.
Refer to the wifi routers mfr support site for help and information regarding there wifi router.
Not all wifi devices will speed test out at anything over 400-500Mbps. Check with your wifi device mfr support site for help and information regarding there speed support.
@jslickmurphy wrote:Our ISP is claiming that our house is receiving the full 600 mbps speed, so they say it has to be our modem or router slowing things down. Our speed test show only 140 mbps on the 5.0 and 40 mbps on the 2.4 The modem says it can get up to 1.4 Gbps. Is there anything I can do in order to get the right speeds to my devices?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try changing the modem. Or contact your service provider to upgrade the service pack
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
