Orbi WiFi 7 RBE973
Reply
Cable modem will not connect to the internet after power outage
egret
I am having trouble with my Orbi CBR 750. When the power is interrupted at my home the wifi system will not show it self and reconnect to my devices until I reset the modem through Xfinity and turn the router on and off several times. When I run the xfinity troubleshooting app it states that there is no issues and the lights are all white on the modem. It seems like the wifi gets turned off by the power outage? Is there a way to stop this from happening? It is difficult when I am out of town. Thanks for your help.
Message 1 of 6
Guru
Re: Cable modem will not connect to the internet after power outage
Message 2 of 6
egret
Firmware Version
V4.6.14.4_2.3.12
Cable Diagnostic
Status: Good
Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
Internet Access: Good
Downstream Status: Good
Downstream Power Level: Good
Downstream SNR: Good
Upstream Status: Good
Upstream Power Level: Good
Current time: Thu Jul 18 21:07:10 2024
Startup Procedure
Acquire Downstream Channel: 555000000 Hz Locked
Connectivity State: Ok Operational
Boot State: Ok Operational
Security: Enabled BPI+
IP Provisioning Mode: Honor MDD honorMdd(4)
Downstream Bonded Channels
Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
1 Locked QAM 256 42 393000000 Hz 2.4 40.9 6 0
2 Locked QAM 256 43 399000000 Hz 2.2 40.9 0 0
3 Locked QAM 256 44 405000000 Hz 2.9 40.9 0 0
4 Locked QAM 256 45 411000000 Hz 2.0 40.3 0 0
5 Locked QAM 256 34 417000000 Hz 2.0 40.3 0 0
6 Locked QAM 256 35 423000000 Hz 2.0 40.3 2 0
7 Locked QAM 256 36 435000000 Hz 1.9 40.9 0 0
8 Locked QAM 256 37 453000000 Hz 2.0 40.3 0 0
9 Locked QAM 256 38 459000000 Hz 1.5 40.9 19 0
10 Locked QAM 256 39 465000000 Hz 1.9 40.3 0 0
11 Locked QAM 256 40 471000000 Hz 1.9 40.9 1 0
12 Locked QAM 256 41 477000000 Hz 1.9 40.3 2 0
13 Locked QAM 256 1 483000000 Hz 1.7 40.3 1 0
14 Locked QAM 256 2 489000000 Hz 2.5 40.3 0 0
15 Locked QAM 256 3 495000000 Hz 1.5 40.3 9 0
16 Locked QAM 256 4 501000000 Hz 2.2 40.9 0 0
17 Locked QAM 256 5 507000000 Hz 2.0 40.3 0 0
18 Locked QAM 256 6 513000000 Hz 2.0 40.9 2 0
19 Locked QAM 256 7 519000000 Hz 2.0 40.9 0 0
20 Locked QAM 256 8 525000000 Hz 2.4 40.3 0 0
21 Locked QAM 256 9 531000000 Hz 2.0 40.3 0 0
22 Locked QAM 256 10 537000000 Hz 2.4 40.9 0 0
23 Locked QAM 256 11 543000000 Hz 2.0 40.9 0 0
24 Locked QAM 256 12 549000000 Hz 2.5 40.3 0 0
25 Locked QAM 256 13 555000000 Hz 2.0 40.3 0 0
26 Locked QAM 256 14 561000000 Hz 2.4 40.9 1 0
27 Locked QAM 256 15 567000000 Hz 2.5 40.3 0 0
28 Locked QAM 256 16 573000000 Hz 2.5 40.3 0 0
29 Locked QAM 256 17 579000000 Hz 2.5 40.9 0 0
30 Locked QAM 256 18 585000000 Hz 2.5 40.9 0 0
31 Locked QAM 256 19 591000000 Hz 2.0 40.3 2 0
32 Not Locked N/A 0 0 Hz 0.0 0.0 0 0
Upstream Bonded Channels
Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
1 Locked ATDMA 8 5120 16400000 Hz 46.5
2 Locked ATDMA 7 5120 22800000 Hz 46.3
3 Locked ATDMA 6 5120 29200000 Hz 46.8
4 Locked ATDMA 5 5120 35600000 Hz 47.8
5 Locked ATDMA 9 1280 39600000 Hz 46.8
6 Not Locked N/A 0 0 0 Hz 0.0
7 Not Locked N/A 0 0 0 Hz 0.0
8 Not Locked N/A 0 0 0 Hz 0.0
Downstream OFDM Channels
Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
1 Locked 3 33 690000000 Hz 1.5 dBmV 42.5 dB 1108~2987 0 0 0
2 Not Locked 0 0 0 Hz 0.0 dBmV 0.0 dB 0~4095 0 0 0
Upstream OFDMA Channels
1 Not Locked 0 0 0 Hz 0.0 dBmV
Event Log
Time Priority Description
Jul 13 2024 15:02:14 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 13 2024 15:02:14 Notice TLV-11 - unrecognized OID
Jul 13 2024 15:02:39 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Dec 31 1969 19:01:00 Critical No Ranging Response received - T3 time-out
Jul 13 2024 15:21:01 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 13 2024 15:21:01 Notice TLV-11 - unrecognized OID
Jul 13 2024 15:21:06 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Dec 31 1969 19:01:02 Critical No Ranging Response received - T3 time-out
Jul 13 2024 15:26:24 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 13 2024 15:26:24 Notice TLV-11 - unrecognized OID
Jul 13 2024 15:26:49 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Jul 14 2024 17:14:38 Notice CM-STATUS message sent. Event Type Code: 24
Jul 14 2024 18:57:40 Notice DS profile config update. DS Chan ID: 33.
Jul 15 2024 08:25:30 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Dec 31 1969 19:01:01 Critical No Ranging Response received - T3 time-out
Jul 15 2024 15:59:36 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 15 2024 15:59:36 Notice TLV-11 - unrecognized OID
Jul 15 2024 15:59:41 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Jul 15 2024 17:55:05 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 15 2024 17:55:05 Notice TLV-11 - unrecognized OID
Jul 15 2024 17:55:10 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Dec 31 1969 19:01:04 Critical No Ranging Response received - T3 time-out
Jul 15 2024 18:00:32 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 15 2024 18:00:32 Notice TLV-11 - unrecognized OID
Jul 15 2024 18:00:36 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Jul 15 2024 18:04:21 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 15 2024 18:04:21 Notice TLV-11 - unrecognized OID
Jul 15 2024 18:04:25 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Dec 31 1969 19:01:03 Critical No Ranging Response received - T3 time-out
Dec 31 1969 19:01:04 Warning RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW
Jul 15 2024 18:08:02 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 15 2024 18:08:02 Notice TLV-11 - unrecognized OID
Jul 15 2024 18:08:06 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Jul 16 2024 12:35:29 Warning MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 16 2024 12:35:29 Notice TLV-11 - unrecognized OID
Jul 16 2024 12:35:34 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Jul 17 2024 09:16:55 Notice DS profile config update. DS Chan ID: 33.
Jul 17 2024 10:05:36 Warning RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Message 3 of 6
egret
TimePriorityDescriptionJul 13 2024 15:02:14Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1Jul 13 2024 15:02:14Notice (6) TLV-11 - unrecognized OIDJul 13 2024 15:02:39Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRWDec 31 1969 19:01:00Critical (3) No Ranging Response received - T3 time-outJul 13 2024 15:21:01Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1Jul 13 2024 15:21:01Notice (6) TLV-11 - unrecognized OIDJul 13 2024 15:21:06Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRWDec 31 1969 19:01:02Critical (3) No Ranging Response received - T3 time-outJul 13 2024 15:26:24Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1Jul 13 2024 15:26:24Notice (6) TLV-11 - unrecognized OIDJul 13 2024 15:26:49Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRWJul 14 2024 17:14:38Notice (6) CM-STATUS message sent. Event Type Code: 24Jul 14 2024 18:57:40Notice (6) DS profile config update. DS Chan ID: 33.Jul 15 2024 08:25:30Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRWDec 31 1969 19:01:01Critical (3) No Ranging Response received - T3 time-outJul 15 2024 15:59:36Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1Jul 15 2024 15:59:36Notice (6) TLV-11 - unrecognized OIDJul 15 2024 15:59:41Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRWDec 31 1969 19:01:02Critical (3) No Ranging Response received - T3 time-outJul 15 2024 17:55:05Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1Jul 15 2024 17:55:05Notice (6) TLV-11 - unrecognized OIDJul 15 2024 17:55:10Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRWDec 31 1969 19:01:04Critical (3) No Ranging Response received - T3 time-outJul 15 2024 18:00:32Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1Jul 15 2024 18:00:32Notice (6) TLV-11 - unrecognized OIDJul 15 2024 18:00:36Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRWJul 15 2024 18:04:21Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1Jul 15 2024 18:04:21Notice (6) TLV-11 - unrecognized OIDJul 15 2024 18:04:25Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRWDec 31 1969 19:01:03Critical (3) No Ranging Response received - T3 time-outDec 31 1969 19:01:04Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRWJul 15 2024 18:08:02Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1Jul 15 2024 18:08:02Notice (6) TLV-11 - unrecognized OIDJul 15 2024 18:08:06Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRWDec 31 1969 19:01:00Critical (3) No Ranging Response received - T3 time-outJul 16 2024 12:35:29Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1Jul 16 2024 12:35:29Notice (6) TLV-11 - unrecognized OIDJul 16 2024 12:35:34Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRWJul 17 2024 09:16:55Notice (6) DS profile config update. DS Chan ID: 33.Jul 17 2024 10:05:36Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Message 4 of 6
egret
Event Log
Clear Log Refresh
Jul 13 2024 15:02:14 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 13 2024 15:02:14 Notice (6) TLV-11 - unrecognized OID
Jul 13 2024 15:02:39 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Dec 31 1969 19:01:00 Critical (3) No Ranging Response received - T3 time-out
Jul 13 2024 15:21:01 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 13 2024 15:21:01 Notice (6) TLV-11 - unrecognized OID
Jul 13 2024 15:21:06 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Dec 31 1969 19:01:02 Critical (3) No Ranging Response received - T3 time-out
Jul 13 2024 15:26:24 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 13 2024 15:26:24 Notice (6) TLV-11 - unrecognized OID
Jul 13 2024 15:26:49 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Jul 14 2024 17:14:38 Notice (6) CM-STATUS message sent. Event Type Code: 24
Jul 14 2024 18:57:40 Notice (6) DS profile config update. DS Chan ID: 33.
Jul 15 2024 08:25:30 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Dec 31 1969 19:01:01 Critical (3) No Ranging Response received - T3 time-out
Jul 15 2024 15:59:36 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 15 2024 15:59:36 Notice (6) TLV-11 - unrecognized OID
Jul 15 2024 15:59:41 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Jul 15 2024 17:55:05 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 15 2024 17:55:05 Notice (6) TLV-11 - unrecognized OID
Jul 15 2024 17:55:10 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Dec 31 1969 19:01:04 Critical (3) No Ranging Response received - T3 time-out
Jul 15 2024 18:00:32 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 15 2024 18:00:32 Notice (6) TLV-11 - unrecognized OID
Jul 15 2024 18:00:36 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Jul 15 2024 18:04:21 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 15 2024 18:04:21 Notice (6) TLV-11 - unrecognized OID
Jul 15 2024 18:04:25 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Dec 31 1969 19:01:03 Critical (3) No Ranging Response received - T3 time-out
Dec 31 1969 19:01:04 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW
Jul 15 2024 18:08:02 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 15 2024 18:08:02 Notice (6) TLV-11 - unrecognized OID
Jul 15 2024 18:08:06 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Jul 16 2024 12:35:29 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1
Jul 16 2024 12:35:29 Notice (6) TLV-11 - unrecognized OID
Jul 16 2024 12:35:34 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Jul 17 2024 09:16:55 Notice (6) DS profile config update. DS Chan ID: 33.
Jul 17 2024 10:05:36 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW
Help Center Show/Hide Help Center
Message 5 of 6
Guru
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 899 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
