- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Download Speed (C7000 V2)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Download Speed (C7000 V2)
A couple ideas.
1. Most isp's (not all) require docsis 3.1 for gigabit speeds. The c7000 is docsis 3.0.
2. Do you have a screen snip of the cable connections page and the logs from the c7000? it allows us to check connections back to isp.
3. If you have any cable splitters, amplifiers, or attenuators in line, remove them. check the coax for kinks/damage/corrosion/bad-cheap connectors/extended runs. Prefereably, connect it where the coax enters the home to rule out wiring within the walls causing the issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
it might also be beneficial to post in the proper forum for your device.
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
