- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Downstream and upstream channel issue; router offline
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Downstream and upstream channel issue; router offline
Procedure Status Comment
Acquire Downstream Channel 0 Hz Not Locked
Connectivity State In Progress Not Synchronized
Boot State In Progress Unknown
Security Disabled Disabled
IP Provisioning Mode In Progress Unknown
Downstream Bonded Channels (Partial Service)
Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
2 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
3 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
4 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
5 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
6 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
7 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
8 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
9 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
10 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
11 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
12 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
13 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
14 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
15 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
16 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
17 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
18 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
19 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
20 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
21 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
22 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
23 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
24 Not Locked Unknown 0 0 Hz 0.0 dBmV 0.0 dB 0 0
Upstream Bonded Channels
Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power
1 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
2 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
3 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
4 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not much to go on when we don't have a NG model # or product reference to what your referring to.
Is this a cable modem or gateway router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
NETGEAR - Nighthawk Dual-Band AC1900 Router with 24 x 8 DOCSIS 3.0 Cable Modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please post a copy and paste of the modems connection status page now that it's up and running?
Is this a C### series modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
1 Locked QAM256 0 549000000 Hz -13.4 dBmV 36.9 dB 0 0
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to check all coax jack fittings and ensure there are no kinks in the coax cable line.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
