Orbi WiFi 7 RBE973
Reply
Lost WIFI signal, credentials missing
sstoots
I have the Nighthawk CAX80 with the latest firmware and it been working flawlessly since I installed it six months ago.
One two occasions this week,  we have lost WIFI.  Both times Comcast reports nothing wrong.       Drilling in administratively , I see the  two SSIDs I renamed are gone.    Once I renamed them assigning what had been the previous no password, everything works again and all devices can now connect as before.
The question is why?   It’s almost as if the router is infected with malware.
Is the latest firmware problematic?   I did update the firmware a few weeks before.
Message 1 of 3
Guru
Re: Lost WIFI signal, credentials missing
Next time (if there is one) that is happens, get a screen snip of the event logs and post them back here. They can show a remote trigger back to factory defaults.
Message 2 of 3
Guru
What specific FW version did you update too?
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 334 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
