- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
My Nighthawk C7000 AC1900 ethernet ports 3 and 4 are not working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Pretty straight forward. I got a new gadget that requires ethernet connection, but either of my ports 3 and 4 are not working. They don't light up even when I plug the one from port 1 or 2.
When I plug the new gadget to port 1 or 2, it works perfectly fine.
Any input would be nice than you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: My Nighthawk C7000 AC1900 ethernet ports 3 and 4 are not working
have you tried plugging any other devices into those ports?
Or tried a different cable (shouldn't matter but worth a shot)?
How old is the device? You've got a 1 year warranty and could go through support to get it replaced if they're for sure bad.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, I've tried unplugging everything and plugging them back in and tried different cables.
I've had these over two years, but I've never had to plug more than 2 ethernet cables before, so I never that ports 3 and 4 are not working.
Does any body's ethernet ports just don't work and have found a way to fix them?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The C7000 is a cable modem/router.
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get better and quicker replies, and find other answers, over in the appropriate section:
Cable Modems & Routers
See if you can find anything relevant over there.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've had a port go bad before. If you've had it over 2 years, you're past the warranty part. you could get a cheap ethernet switch and add in. Cheaper than replacing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Can add a external switch with 5 to up to 24 or beyond if you want.
If you keep loosing port usage, then the C7000 may be to be replace at some point.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
