Orbi WiFi 7 RBE973
Reply
Netgear router and modem
smumbauer999
Follower
Ok question so i am wanting to buy a netgear router and modem do i need a coax cable to set up internet or can i connect it via ethernet then connect it to my computer and set wifi on that?
Model: CM700|High Speed Cable Modem—DOCSIS 3.0, R6300v2|AC1750 Dual Band Gigabit router
Message 1 of 2
Guru
Re: Netgear router and modem
Who's your ISP?
If you're looking for a modem, you first want to make sure its compatible with your isp before buying anything.
Have you checked with them on compatible modem/routers?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 416 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
