Orbi WiFi 7 RBE973
Reply
New - CAX30 Firmware Version 1.4.11.2 Released
Guru
New Features and Enhancements: 11/30/2022
•    Bug Fixes
Download Link:
https://www.netgear.com/support/product/cax30.aspx#download
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/
enter your model number in the search box, and click the Documentation button on the product page.
NOTE: This upgrade is for the ROUTER portion of the CAX only. Modem portion Firmware upgrades are pushed down by your ISP. For more information, please see our  https://kb.netgear.com/000036375/What-s-the-latest-firmware-version-of-my-NETGEAR-cable-modem-or-mod...
Manually update FW on the router if this isn't seen on the routers web page:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
NOTE: Use a wired PC and web browser to update router FW. If continued problems are seen after a FW update, it's recommended to try a factory reset and setup from scratch with out loading any saved configurations from backup files.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This article applies to:
Let us know how it works for you in this thread please.
Message 1 of 4
EricH195
Re: New - CAX30 Firmware Version 1.4.11.2 Released
Nighthawk tells me the latest firmware is installed and there are no upgrades. Will this be different if I use a wired PC and browser?
Message 2 of 4
Kitsap
Master
Maybe yes and maybe no.  That is the problem.  Experienced users have more consistent success doing a manual update of their router via a web browser on a computer connected to the router with an Ethernet cable.  In general, download the new firmware (it is in a .zip file) to your computer, unpack the binary (.bin) file from the zip file, log in to the user interface, go the the Advanced -> Administration -> Update Firmware page.
See details here:  https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Message 3 of 4
Guru
Which NIghthawk are you referring too? The Modem or the Nighthawk mobile app?
Message 4 of 4
Discussion stats
  • 3 replies
  • 1362 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
