- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk c7800 cable modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk c7800 cable modem
do you have a screen snip of the cable connections page and the logs?
those help us more than just telling us what some of the values are.
they don't "change" the power levels. to change them they'd actually have to come out and check lines which is why a call rarely helps the first time.
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not giving you grief but if the modem's offline, he couldn't have remote rebooted/reset it. Since it isn't online.
If you take a screensnip, it should be in the proper format and you can click on "choose file" to add.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Downstream OFDM Channels
Channel Channel ID Indicator Subcarrier Zero Frequency Active Subcarrier Number Range Total Codewords Uncorrectable Codewords
1 25 Non-Primary 713600000 Hz 1108 ~ 2987 2431991 0
2 0 Other 0 Hz 0 ~ 0 0 0
Upstream OFDMA Channels
Channel UpstreamIsMuted Ranging Status Subcarrier Zero Frequency Active Subcarrier Number Range Symbols Per Frame Tx Power
1 Other 0 Hz 0 ~ 0 0 0 dBmV
2 Other 0 Hz 0 ~ 0 0 0 dBmV
Current System Time: Sun, Jan 17, 2021 18:07:21
Time Priority Description
2021-01-17, 11:03:02 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:ce:b3:00;CMTS-MAC=00:01:5c:71:72:67;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Notice (6) Honoring MDD; IP provisioning mode = IPv6
Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:ce:b3:00;CMTS-MAC=00:01:5c:71:72:67;CM-QOS=1.1;CM-VER=3.1;
Time Not Established Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=08:36:c9:ce:b3:00;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2021-01-17, 08:48:36 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=08:36:c9:ce:b3:00;CMTS-MAC=00:01:5c:71:72:67;CM-QOS=1.1;CM-VER=3.1;
2021-01-17, 08:47:28 Critical (3) Resetting the cable modem due to docsDevResetNow
2021-01-17, 08:46:44 Critical (3) SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:ce:b3:00;CMTS-MAC=00:01:5c:71:72:67;CM-QOS=1.1;CM-VER=3.1;
2021-01-17, 08:42:10 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:ce:b3:00;CMTS-MAC=00:01:5c:71:72:67;CM-QOS=1.1;CM-VER=3.1;
2021-01-17, 08:41:53 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=08:36:c9:ce:b3:00;CMTS-MAC=00:01:5c:71:72:67;CM-QOS=1.1;CM-VER=3.1;
2021-01-17, 08:41:53 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:ce:b3:00;CMTS-MAC=00:01:5c:71:72:67;CM-QOS=1.1;CM-VER=3.1;
2021-01-17, 08:41:08 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=08:36:c9:ce:b3:00;CMTS-MAC=00:01:5c:71:72:67;CM-QOS=1.1;CM-VER=3.1;
2021-01-17, 08:41:07 Critical (3) Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=08:36:c9:ce:b3:00;CMTS-MAC=00:01:5c:71:72:67;CM
[remote login] from source fe80::1025:7716:83b:2f5b, Sun, Jan 17, 2021 18:05:39
[admin login] from source 192.168.0.38, Sun, Jan 17, 2021 18:04:22
[DHCP IP: (192.168.0.38)] to MAC address e2:ce:43:82:94:b9, Sun, Jan 17, 2021 18:03:47
[DHCP IP: (192.168.0.3)] to MAC address 00:05:cd:39:fb:e0, Sun, Jan 17, 2021 16:58:06
[Internet connected] IP address: 73.134.72.134, Sun, Jan 17, 2021 16:49:04
[Internet disconnected] Sun, Jan 17, 2021 16:48:35
[DHCP IP: (192.168.0.37)] to MAC address d8:0f:99:5f:f5:81, Sun, Jan 17, 2021 16:37:15
[DHCP IP: (192.168.0.35)] to MAC address 0a:93:e2:1b:e8:27, Sun, Jan 17, 2021 16:30:25
[DHCP IP: (192.168.0.34)] to MAC address c8:fd:19:80:ce:95, Sun, Jan 17, 2021 16:06:19
[DHCP IP: (192.168.0.29)] to MAC address 00:7c:2d:2a:45:9e, Sun, Jan 17, 2021 16:05:04
[DHCP IP: (192.168.0.23)] to MAC address 98:84:e3:db:15:61, Sun, Jan 17, 2021 16:04:25
- Mark as New
- Bookmark
- Subscribe
- Permalink
please take a snip as its easier to read/interpret
Open Snipping Tool and take a screenshot (microsoft.com)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The inserts photo option didn't work so here is the event logs.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Got a few more files. Those numbers seem to be all over the place and not what it should be per someone eles post with the same modem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
And no amplifiers in line? Or anything else?
your upstream power is low and its going to cause issues.
And you're log is indicating line/power issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What I've had to do with comcast before is to rent a modem from them for a month/2 to prove that it wasn't a modem issue.
many times they're set that the line is fine.
but they truly can't just "turn up the upstream power". thats the modem negotiating with the cmts for what power level it needs to use to communicate with it. It could be an issue with the cmts.
- Mark as New
- Bookmark
- Subscribe
- Permalink
