Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Replacement power adapter for CM1000v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-07-30
05:25 PM
2020-07-30
05:25 PM
Where could I purchase a replacement power adapter for the CM1000v2 cable modem? Any help would be appreciated.
Message 1 of 5
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-07-30
07:19 PM
2020-07-30
07:19 PM
Re: Replacement power adapter for CM1000v2
Try places let Amazon. Look for same spec voltage and amps as listed on the sticker of the power adapter.
Message 2 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-07-30
07:53 PM
2020-07-30
07:53 PM
Does it have to be a Netgear power adapter? Will the modem be compatible with any power adapter as long as the volts and amps are correct?
Message 3 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-07-30
07:56 PM
2020-07-30
07:56 PM
Correct, as along as the volts, amps and size of plug are the same, the modem will work fine with non NG branded power adapters.
Message 4 of 5
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-07-30
08:02 PM
2020-07-30
08:02 PM
What do you mean by size of the plug? Are you talking about the part that plugs into the modem? If so, how would I be able to find out if it would fit before buying?
Message 5 of 5
Announcements
