- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router config
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router config
Hello,
I had my router set up and working fine for months. Then, what seems like all of a sudden, i lost connection to every device in my house. I called my ISP, they sent a tech, and verifired no issues on thier end.
My WIFI netowrk, which i re-named has reset back to NETGEAR. I did not perform a factory reset, so not sure why it would do this. I am able to connect my devices to this network now, but when i try to access the GUI, i log in, to routerlogin.net, but the only option i have is to change my password. When I change it, nothing happens after.
Any ideas, should i perform a factory reset?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router config
Please post in this forum for your modem/router combo unit:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router config
So after changing the SSID from NETGEAR to something else, devices would not connect to the newer SSID name?
Yes, do a factory reset and setup from scratch. When given the opportunity, change the SSID from the default one to something different. Can be anything you chose. Then see if your devices connect. You may need to tell the devices to forget there prior settings, reboot then try to connect to the new SSID name.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router config
- Mark as New
- Bookmark
- Subscribe
- Permalink
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
