- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Time to Replace CM1100?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Xfinity tells me my modem, CM1100, is 3 years old and is causing connection issues with my internet service. Does this seem accurate?
DOCSIS® 3.1 Cable Modem (CM1100)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Time to Replace CM1100?
No. Someone at the ISP is trying to get you to spend money elsewhere.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-m...
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-mode...
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the brand and model of the host wifi router connected to the modem?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for helping.
It's connected to a Netgear Nighthawk Mesh SiFi 6 Router (MR60).
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm trying to post the copy/past, but the forum won't let me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Frequency start Value | |
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |
<tabindex=-1>Startup Procedure</tabindex=-1>
Procedure | Status | Comment |
Acquire Downstream Channel | 543000000 Hz | Locked |
Connectivity State | OK | Operational |
Boot State | OK | Operational |
Security | Enable | BPI+ |
IP Provisioning Mode | Honor MDD | IPv6 only |
- Mark as New
- Bookmark
- Subscribe
- Permalink
<tabindex=-1>Upstream Bonded Channels</tabindex=-1> | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Downstream OFDM Channels</tabindex=-1> | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1> | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
Current System Time: Wed Nov 01 15:57:15 2023 | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
System Up Time: 0:55:30 |
- Mark as New
- Bookmark
- Subscribe
- Permalink
Ok, I think I was able to post what was requested.
Looking forward to sorting this out.
Thanks!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please post the entire data on the connections page along with the data from the events log page.
You can copy and paste into a word doc then export to PDF file than attach to your next post if that helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Power levels are good.
I see lots of correctable codewords on the one OFDMA channel at the bottom that I believe should be mostly zero. Something the ISP should look at.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Mod...
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
- Mark as New
- Bookmark
- Subscribe
- Permalink
When Xfinity does a check of the modem, can they see this data?
Or do I need to provide it to them?
- Mark as New
- Bookmark
- Subscribe
- Permalink
