TonyLinguini's avatar
TonyLinguini
Trying to use external MyBook for network backup
I tried to use my old MyBook to do thia and it would not show up. I tried a thumb drive and it showed up fine. So I researched on this site and found a different model suposedly compatible. I bought it but it does not work,
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello Tonylinguini
    Have you tried to format the drive and make sure its NTFS and Fat32 file format?
    DarrenM
    • TonyLinguini's avatar
      TonyLinguini
      It was NTFS, but it was 3TB. I separated it to 2 - 1.5TB partitions and it saw it fine. However, it is not practical to use it for network backup because it is sl-o-o-o-o-w. Thank you.
