Orbi WiFi 7 RBE973
Reply
Unable to Get into Router Settings to change Ghz Setting
beachbum561fla
Attached is the error I got. I don't know what's going on. All I did was update the software because the update popped up.
The reason I am trying to change the Ghz setting is because my security cameras I just bought said they do not work on 5ghz network.
Message 1 of 4
Guru
Re: Unable to Get into Router Settings to change Ghz Setting
What NG product do you have?
Message 2 of 4
beachbum561fla
It's a CM1200... I guess the form didn't save it and I can't edit my original post?
Message 3 of 4
That's a cable modem. No router in there. So no wifi, or GHz, involved.
CM1200 | Product | Support | NETGEAR
It usually sits in front of a router that does the wifi stuff.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 552 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
