- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
can C6300 is used as wireless AP ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi I am trying to set up C6300 as wireless AP. I haven't seen AP mode in router configuration settings. Please let me know if I am missing something. I have done search on this topic but didn't find any articles for this model.
My Set up: I have an existing att wifi set up with pace 5268ac already in place. In all my rooms I have a hard wired ethernet cables connected to my existing att modem/router. In one of the wifi dead spots I want to use this router as a wireless acess point. Any help I would really appreciate it. Some of the articles I followed are.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: can C6300 is used as wireless AP ?
No it can not do this.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
It can be used as an Access Point - there is just no specific setting in the GUI. I am using mine as an access point now. Just perform the following steps:
Connect to the C6300 and make the following changes:
- Set the LAN IP to an IP that is not the IP of your primary router (typically 192.168.0.1) AND is not in the range of your current DHCP settings (Modify your DHCP settings if needed). I have mine set to XXX.XXX.XXX.2.
- Change your wireless settings for both 2.4Ghz and 5Ghz to the same name, password, and security settings as your primary router. This allows you to have your connected devices roam and use the strongest signal without having to reconnect.
- Change the channel for both wireless bands to something different than your primary router. i.e. if primary uses channel 1 for 2.4Ghz and 44 for 5Ghz, set the C6300 to channel 11 for 2.4 and 157 for 5Ghz. Hint: use an app on your phone like WiFiAnalyzer to see what channels are currently in use around your house - try to avoid overlap as much as possible to improve performance.
- Turn off DHCP. You only want IP managed by your primary router.
That's it! Now connect the C6300 to your network, and it acts like an access point!
I realize that this does not make it a wireless Access point, but thought others might want to do this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] Just perform the following steps: [...]
Or:
https://community.netgear.com/t5/x/x/m-p/1463500
Though it's not clear that anyone cares these many months later.
User | Count |
15 | |
4 | |
3 | |
2 | |
2 |
