Orbi WiFi 7 RBE973
Reply
no wi-fi connections found
crossroads
Wi-fi not doesnt have a valid IP configuration.....error message from my laptop.  all other devices in my house work.
Message 1 of 8
Accepted Solutions
crossroads
Re: no wi-fi connections found
It seems to be working now.  It was a simple fix of changing the power option to "maximum performance" and restarting my computer.  I will see if this takes care of the problem.  Thank you for your help.
Message 8 of 8
All Replies
Guru
Please give us the router model and the firmware it is running.
Though this sounds more like a PC issue than a router issue.  Can you give us the exact wording of the error message (a screen shot would be best).
Message 2 of 8
crossroads
N600 WiFi Cable Modem router
Model #C3700
The exact message:  Wi-Fi doesn't have a valid IP Configuration
Message 3 of 8
crossroads
Also:
Problem with wireless adapter or access point
Wi-Fi doesn't have a valid IP configuration
Message 4 of 8
Guru
Did you try connecting over ethernet, and making sure that worked?
Also, what version of windows, and what is the wifi adapter model in the PC?
Message 5 of 8
crossroads
windows 10..I have no idea where to find the wifi adapter model in the PC.  And I don't know how to connect over the ethernet
Message 6 of 8
Guru
You connect over ethernet by connecting an ethernet cable between the PC and the router.
Use one of the ways in this link to open the windows device manager: http://www.isunshare.com/windows-10/7-ways-to-access-device-manager-in-windows-10.html  Once that is running, look at the network adapter section.  The wifi adapter will be in there.
Here's one thing you can try: https://www.youtube.com/watch?v=CJQOtXU4gJQ
Message 7 of 8
crossroads
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 4204 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
