Orbi WiFi 7 RBE973
Reply
CM1000 How to stop daily reboot
BennyBenX
Hello I need help troubleshooting why my modem restarts itself every day at a specific time. I'm not sure if it's because of a DHCP lease time or something else. Here are some log messages on my modem.
I've already tried factory resetting the modem and the problem still occurs.
Thanks.
Cable Information
Hardware Version2.02
Firmware VersionV7.01.01
Cable Modem Serial Number4L0585WA00F59
CM certificateInstalled
CM MAC08:36:c9:a5:8f:28
2020-08-03, 03:24:22Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=08:36:c9:a5:8f:28;CMTS-MAC=00:01:5c:ac:0c:49;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedNotice (6)Honoring MDD; IP provisioning mode = IPv6
Time Not EstablishedCritical (3)No Ranging Response received - T3 time-out;CM-MAC=08:36:c9:a5:8f:28;CMTS-MAC=00:01:5c:ac:0c:49;CM-QOS=1.1;CM-VER=3.1;
Time Not EstablishedCritical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=08:36:c9:a5:8f:28;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
2020-08-03, 03:22:09Critical (3)SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=08:36:c9:a5:8f:28;CMTS-MAC=00:01:5c:ac:0c:49;CM-QOS=1.1;CM-VER=3.1;
Frequency start Value
This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect.
Starting Frequency
<tabindex=-1>Startup Procedure</tabindex=-1>
ProcedureStatusComment
Acquire Downstream Channel441000000 HzLocked
Connectivity StateOKOperational
Boot StateOKOperational
SecurityEnableBPI+
IP Provisioning ModeHonor MDDIPv6 only
<tabindex=-1>Downstream Bonded Channels</tabindex=-1>
ChannelLock StatusModulationChannel IDFrequencyPowerSNR / MERUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1LockedQAM2561441000000 Hz0.8 dBmV40.9 dB127485413200
2LockedQAM2562453000000 Hz0.7 dBmV40.8 dB127362512400
3LockedQAM2563459000000 Hz1.0 dBmV40.9 dB127361591500
4LockedQAM2564465000000 Hz1.9 dBmV41.4 dB127363187500
5LockedQAM2565471000000 Hz2.4 dBmV41.4 dB127363562900
6LockedQAM2566477000000 Hz3.2 dBmV41.7 dB127364013000
7LockedQAM2567483000000 Hz3.3 dBmV41.7 dB127364338900
8LockedQAM2568489000000 Hz3.8 dBmV42.1 dB127364731200
9LockedQAM2569495000000 Hz4.0 dBmV42.2 dB127365289100
10LockedQAM25610501000000 Hz4.3 dBmV42.1 dB127365604300
11LockedQAM25611507000000 Hz4.5 dBmV42.3 dB127366022200
12LockedQAM25612513000000 Hz4.6 dBmV42.4 dB127366344900
13LockedQAM25613519000000 Hz4.3 dBmV42.1 dB127366749900
14LockedQAM25614525000000 Hz4.0 dBmV41.7 dB127367153800
15LockedQAM25615531000000 Hz3.4 dBmV41.4 dB127367527200
16LockedQAM25616537000000 Hz3.3 dBmV41.4 dB127367917200
17LockedQAM25617543000000 Hz3.8 dBmV41.6 dB127369044900
18LockedQAM25618555000000 Hz4.2 dBmV41.7 dB127369492400
19LockedQAM25619561000000 Hz4.1 dBmV41.5 dB127369766900
20LockedQAM25620567000000 Hz3.7 dBmV41.4 dB127370204600
21LockedQAM25621573000000 Hz3.8 dBmV41.5 dB127370583200
22LockedQAM25622579000000 Hz3.9 dBmV41.4 dB127370980700
23LockedQAM25623585000000 Hz3.7 dBmV41.2 dB127371272900
24LockedQAM25624591000000 Hz3.8 dBmV41.2 dB127371682100
25LockedQAM25625597000000 Hz3.7 dBmV41.1 dB127372124100
26LockedQAM25626603000000 Hz3.3 dBmV41.0 dB127371994900
27LockedQAM25627609000000 Hz3.5 dBmV41.0 dB127372225000
28LockedQAM25628615000000 Hz3.4 dBmV40.8 dB127372342300
29LockedQAM25630621000000 Hz3.5 dBmV40.6 dB127372214800
30LockedQAM25631627000000 Hz3.3 dBmV40.6 dB127370368500
31LockedQAM25632633000000 Hz3.9 dBmV41.0 dB127370385100
32Not LockedUnknown00 Hz0.0 dBmV0.0 dB000
<tabindex=-1>Upstream Bonded Channels</tabindex=-1>
1LockedATDMA136500000 Hz53.0 dBmV
2LockedATDMA230100000 Hz53.5 dBmV
3LockedATDMA323700000 Hz53.3 dBmV
4LockedATDMA417300000 Hz53.0 dBmV
5Not LockedUnknown00 Hz0.0 dBmV
6Not LockedUnknown00 Hz0.0 dBmV
7Not LockedUnknown00 Hz0.0 dBmV
8Not LockedUnknown00 Hz0.0 dBmV
<tabindex=-1>Downstream OFDM Channels</tabindex=-1>
ChannelLock StatusModulation / Profile IDChannel IDFrequencyPowerSNR / MERActive Subcarrier Number RangeUnerrored CodewordsCorrectable CodewordsUncorrectable Codewords
1Locked0, 1, 2, 329693000000 Hz5.2 dBmV38.8 dB1108 ~ 29872136819731991361100
2Not Locked000 Hz-0.7 dBmV0.0 dB0 ~ 4095000
<tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
1Not LockedUnknown00 Hz0 dBmV
2Not LockedUnknown00 Hz0 dBmV
Model: CM1000-1AZNAS|Ultra-High Speed Cable Modem—DOCSIS® 3.1 Ready
Message 1 of 5
Tbones3141
Re: CM1000 How to stop daily reboot
Same issue just started. I have the same firmware. What gives? Anyone got ideas?
Message 2 of 5
Guru
Any progress on this?
Thanks.
Message 3 of 5
Guru
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Message 4 of 5
vkdelta
NETGEAR Expert
extremely high Upstream power. It is blasting at 53dBmV right now which is very high.
do you have any splitters?
If not, you should request ISP to reduce the US attenuation.
Message 5 of 5
Discussion stats
  • 4 replies
  • 957 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
