ezjose1's avatar
ezjose1
CM600 Can't Get it Connected to Optimum online ip provisioning
I'm trying to activate a CM600 cable modem with optimum online and they're having an issue that the modem comes in and out of the network and they can't activate it. After doing some research I am thinking that it is stuck in IPv6 mode the modem currently has installed firmware V1.01.14 is there any way to get the firmware updated to V1.0.1.16 without connecting it to a service provider that has that firmware and then network is IPv6 enabled. I believe my issue is because optimum online is IPV4 and I am getting an error I believe. The modem does seem to connect to the network but then drops in and out with error messages within the logs.
