- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Comcast and CM700 speed issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Been reading the forum... and think there is not much i can do before Comcast tech comes out, but wanted to post here to make sure i had answers ready.
few months old CM700 - pay for 150Mbps .... noticed slower speeds recently. getting 30Mbps, even when PC connected directly to modem. Have done all the usual resets, etc.
Checked the firmware on the modem against the lastest posted by Netgear, and it looks like they are the same. WHAT IS WEIRD is that teh firmware page on Netgear.com was updated on 2/8/18, leading me to possibly believe that is when the newer firmware came out. The coincidental part is that if you look at my logs (which actually only go back to 2/8), that's when the T4 and T3 critical errors started. Any idea what might be going on here, other than having the tech check the outside lines?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Comcast and CM700 speed issues
Please post the power values from the connection page.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
your screenshots did not show up. Please attach the files again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
looking right at them in this thread... you can't see them?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Tomgru
The power on the first couple downstream channels is high it should be between -7 to +7 and the timeouts could be a sign of signal issues. You will want a tech to check the lines or remove any splitters connected to your cable modem and see if it improves.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Darren. Tech was there last night and concluded pretty similar... but from tap in neighborhood to my house. Need to run new cable ... will take 2-3 weeks at best. (ugh). At least i have ~30 Mbps still, so i shouldn't complain too much.
Will try to remember to report back and see if that fixes the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
ironically... yesterday they dropped an entire new line under the street... all back to normal.
