Orbi WiFi 7 RBE973
Reply
Order status
HotRock1
Follower
Order status
pre ordered the new NETGEAR Nighthawk DOCSIS 3.1 32x8 Multi-Gigabit Cable Modem (CM2000)
order status says Exeption. cant get ahold of netgear for any info so, JW if anyone happens to know what it means.
Message 1 of 2
Guru
Re: Order status
Something that you'll need to contact NG support about. Something that would not be handled here in the forums.
Good Luck.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 270 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
