Fix1tN0w's avatar
Fix1tN0w
Remote Management
Is the Nighthawk capable of being remote managed or not? I can't get a straight answer. I want the ability to reboot router from iPhone while out of town. Who can answer this and how? Please
  • schumaku's avatar
    schumaku
    Definitively possible - permitting your Nightawk router is supported by the Nighthawk App, and having linked the Nightawk App to oyur [My]Netgear Account following the initial installation:
    While on the device local [W]LAN ... How do I enable remote access on my router using the Nighthawk app?
    Now the device registered does show up in the Remote Management - Your Products list.
    While connected remotely (or locally) click on the big device icon on top - find Router Settings and a red [Reboot] button.
    • Fix1tN0w's avatar
      Fix1tN0w
      Incorrect, I have a Nighthawk C7000 device. Not in Netgear list for that app. I'm currently using NO-IP as DNS Service and it works. Can someone point me to correct setup for app to remote connect and reboot router? thanks
      • antinode's avatar
        antinode
        Guru
        > Is the Nighthawk [...]
           _Which_ "the Nighthawk"?
        > Incorrect, I have a Nighthawk C7000 [...]
           An actual model number usually works better than an ambiguous
        marketing description.  Not "C7000v2"?
           Visit http://netgear.com/support , put in your model number, and look
        for Documentation.  Get the User Manual.  Look for "Remote Management".
  • vkdelta's avatar
    vkdelta
    NETGEAR Employee Retired
    No NightHawk Cable Routers currently are capable of "Remote management" from app. (future ones may but not the current ones).
    It can only support remote HTTP mgmt if you enable it from GUI.
    if you want a Cable gateway with remote mgmt, you might want to check CBR40 or CBK40.
