- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
n300 model 2700 cannot establish connection with COMCAST
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have Comcast as Internet provider in the East Bay. The Internet was working well for the last three months. Suddenly, the WiFi stopped working about three days ago and now can't establish Intenet connection. How do I now whether the problem is wiht my router or with Comcast? The same co-ax cable gives TV okay. Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: n300 model 2700 cannot establish connection with COMCAST
Is it only an Internet connection that you do not have, i.e. does the computer establish a WiFi connection with the LAN? What error messages do you see? Have you tried using a wired connection to the router to confirm internet access via the modem works?
What is the full model number of the N300? It's not an EX2700 range extender is it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Q: Have you tried using a wired connection to the router to confirm internet access via the modem works? A: No, it dos not work. It says "No Internet Access". "Internet LED" is off. Computer can't conect to ISP server, I believe. The Model # is C3000.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So you have a C3000 cable modem/router, the ‘2700’ in the thread title was confusing?
If your cable modem is showing no Internet connection then you need to check with your ISP to see if there are any issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes, probably.
Finally customer support had to Ctr+Alt+Del a.k.a. hard Reset. I tried first with the bottom pin hole, could not do it, then I was guided to do via browser Advanced Administration option. I found it in the Users Manual. Thanks ot all of you to guide me and the phone support lady.
