D0N
Jan 30, 2018Aspirant
reset SSID and security key
Router 20 feet from PC (where cable enters dwelling); can bring router to PC but not PC to router; if I bring router to PC must a cable connection be maintained?
Router had reset to factory default. Can you change to your own SSID and security key
without a direct Ethernet connection? If so how or send me instructions or link
if not does the router have to be connected to the cable while doing it?
Question not clear.
What trying to do?
Can you change to your own SSID and security kwithout a direct Ethernet connection?
Tried Netgear genie? (Desktop and/or mobile app.)
- D0NAspirant
Apologize for not being clear. I'll try another way.1. my router reset itself to factory settings;
2. I would like to rerset my SSID and security key to what I had before the reset. 3. My problem is my desktop is twenty feet away from my router, so bringing the computer to connect to the router is impractical unless I can find a 20 foot ethernet cord! 4.So, if I bring the router to the desktop I can connect to the desktop but if I do that I will have to disconnect the cable;does the cable have to be connected for the reset to be completed?
5. At the moment my other computer, ( laptop) just crashed so I don't have that option until I figure out what I am going to replace it with. Any enlightenment would be appreciated thanks, Don
Have you looked into using the Netgear desktop genie?
> Can you change to your own SSID and security key without a direct
It should work. After you reset the router, you should be able to
connect to it wirelessly using the default credentials (SSID,
passphrase) on the label. When you change the wireless-network
credentials, I'd guess that you'll get disconnected, and you'd need to
reconnect using your new (non-default) credentials.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read.
> it?
It's easier with a wired connection, because changing the
wireless-network credentials should not affect a wired connection.
