× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Few feature requests for MR1100 EUS
AoC
Guide
Guide
Hello! I have used the device for two months now. Following features would be nice to have:
  • More comprehensive signal info to the diagnostics page, like working SINR , MCS,  Modulation (both DL and UL for each CC  , list of CC with sufficient signal info, like on telnet console.
  • Amount of used data -counter is zeroing after a SIM-card swap. Please make it persist longer.
  • LTE band locking. Sometimes it's just needed to lock the band manually. Logic of the radio network should do, but sometimes automatic systems just fails. This is a problem when you are in a rural area where are both B3 and B20 signals available, while B3 is unusable low/poor in quality. The device likes to choose it despite the fact data connection fails or DL/UL speeds are very poor compared to the B20, which is available.
And I have found some bugs too:
  • WIFI performance is poor if you are using Samsung smartphones. S6, S8 and S9 (exynos variants) are confirmed to have bad wifi speeds on Netgear, both 2,4 and 5GHz. This means ~50% lower speeds than on other devices (Qualcomm Snapdragon powered smartphones, laptops with Intel Wifi chips...)
  • Sometimes device faces  a sudden crash. It doesn't count if I'm actively using the device at the moment of crash or not. Device just shuts down itself and replacing a battery is needed to get it back working. Crashdump shows following info:
Src: FatalError
Dat: 0000011D
Str: sys_m_smsm_mpss.c
Fmt: APPS force stop
00000000 00000000 00000000 00000000
Task: AMSS0
Time: 000FE58D
R0: 00000000 R1: 00000000 R2: 00000000 R3: 00000000 R4: 00000000
R5: 00000000 R6: 00000000 R7: 00000000 R8: 00000000 R9: 00000000
R10: 00000000 R11: 00000000 R12: 00000000 R13: 00000000 R14: 00000000
PC: 00000000
CPSR: 00000000
Mod: Unknown
Ctr: ARM, IRQ en,FIQ en
TOS
00000000 00000000 00000000 00000000 00000000 00000000 00000000
BOS
App ver:NTG9X50C_12.02.07.00
Src: FatalError
Dat: 00000000
Str: Recursive fault!
Task:
Time: 00000000
PC: 00000000
CPSR: 00000000
Mod: Unknown
TOS
BOS
Message 1 of 2
JasonN
NETGEAR Employee Retired
Re: Few feature requests for MR1100 EUS
Hi A0C,
Thank you for your suggestions and findings! :]
I will forward this to my internal team for them to look at and see what they want to do with this.
- Jason N
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1275 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
