× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
Firmware for Nighthawk M1 Failure to update (NTG9X50C- 12.02.06.01)
Feeldennis
Tutor
Hello Community,
     I got a branded ATT Night hawk M1 portable router, I unlocked with the unlock codes.
Right now it is working fine.
But, the firmware update never works.
Since I am on an older firmware, I don’t have the option of manually downloading the firmware and updating via the web interface.
  1. What other options are there to update the firmware?
  2. Is there any executable firmware that could be run and would update the device plugged in via usb.
  3. Since I have unlocked the device, cant I change the ATT logo to something else?
  4. Data Usage: I can’t edit my data usage or set limits etc.
Model: MR1100|NIGHTHAWK M1
Message 1 of 3
Blanca_O
NETGEAR Moderator
Re: Firmware for Nighthawk M1 Failure to update (NTG9X50C- 12.02.06.01)
Hi Feeldennis,
Just to verify, are you using an AT&T Sim when running the update?
Though the device is unlocked, you cannot change the AT&T logo.
Blanca
Community Team
Message 2 of 3
Feeldennis
Tutor
Hi,
   I am not using an AT&T sim card while trying to up date.
Thanks
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1819 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
