- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
LB2120 : Power Light Amber
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I bought 2 units of Netgear LB2120-100PES. They are used in France with SFR Operator.
Every few days, the modems are stuck with Power Led Amber, Signal is full and green and network led is green.
Need to reboot the modem each few days for having again internet, which is not acceptable for my customers...
I have the same issue with the 2 modems. They are up to date firmware, and factory default has already be done on each one.
Do you have a fix firmware for this kind of issue? Or do I need to buy another modem from other manufacturer?
Thanks a lot in advance.
Kind regards,
Julien R.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: LB2120 : Power Light Amber
Hello,
same problem here, with FREE operator in France too.
In our case, the netgear LB2120 is not connected to a wan network.
It is connected to our firewall as a backup internet access.
Could someone from Netgear help us with this problem ?
Thanks
Michel D.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Michel
Don't waste your time, buy one from another brand. I did the same for 2 customers, no more issues....
I have tested 1 week ago is there is a new firmware from Netgear by OTA, nothing...
Buy a Huawei model...
Julien
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Julien
in my case, this is "only" a backup internet access point in case our fiber link is down.
By the moment, I set the LB2120 as a "router" (not a bridge => operation mode = router) and I manually selected the FREE network (network selection mode = manual)
I also forced the netgear to always operate in 4G mode (default connexion = mobile broadband only)
By the moment, it seems to work (I deliberately plug out the fiber modem ethenret link yesterday to see how the firewall and the netgear modem would handle it = ok)
This morning, the netgear is still available throught the network (192.168.5.1) and all lights are correct (power light = green)
I will report back if it randomly goes "amber" like it did when set as a "bridge".
But it seems in my case, this was the bridge mode that is not really stable or supported in my network configuration.
Michel D.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This sounds the same issue as posted here
