Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
M6 not connecting to 5G
d4bbott
MR6110-1A1NAS. HW Version 1.0  FW Version NTGX65_10.01.22.01
All cellular devices in my household recognize the 5G cellular network. My Nighthawk M6 will not allow the 5G settings for the APN. It acts like there are too many characters. The 5G APN is ATT NR Broadband, it will stop at Broadban. I've tried no spaces, still no luck. I've reset, done a hard reset, removed and reinstalled SIM card. The SIM was previously in an M1 but ATT recognizes the M6 as a 5G device in my devices.
Message 1 of 14
Accepted Solutions
d4bbott
Re: M6 not connecting to 5G
I broke down and took everything to a local AT&T store. They confirmed that I had done everything right, the device is a 5G device, and I have 5G service where I live. They also confirmed that this was not the first time they had heard of such an issue. Turned out to be a SIM card issue. They took a new SIM card, provisioned it to a 5G device in the store, installed it into the M6, and now I have 5G service with my hotspot.
Message 5 of 14
All Replies
madiwilly
Tutor
Are you doing this through the app or on your browser?
I use my browser and it seems to still work as of the latest update.
To navigate in your browser on a PC go to http://192.168.1.1/
Then go to Settings>Advanced>Cellular
You should be able to edit the APN from there.
I am using the APN "broadband" and still get 5G on the AT&T network. You can also try "nrbroadband" though. They both seem to do the same thing on my router.
Also, make sure you are doing the APN Name as "ATT NRBroadband", and the actual APN is just "nrbroadband".
Message 2 of 14
madiwilly
Tutor
Attached to this is an example of my APN settings.
Message 3 of 14
d4bbott
I've tried both the app and desktop with no luck. I've also tried every combination of APN I can imagine. I've tried your configuration also with zero connectivity.
Thank you for helping.
Message 4 of 14
d4bbott
Message 5 of 14
MobileGerman
Betreff: M6 not connecting to 5G in Germany
My MR6110-1A1NAS_05.00.63.00 is not connecting to German 5G networks only to 4G/LTE.
SIM-card gives access to 5G Telekom networks
FW NTGX65_10.04.22.00
Any idea how I could fix the issue?
Message 6 of 14
W1lliam
Virtuoso
MR6110-1A1NAS only supports n2/n5/n12/n14/n29/n30/n66/n77 while Germany carriers is on n1/n3/n28/n78, not a suitable model for the country you are staying.
Message 7 of 14
MobileGerman
Thanks for your explanation!
Which model is suitable for 5G in Europe/Germany?
Message 8 of 14
W1lliam
Virtuoso
MR6150-100EUS(NSA/SA), MR6450-100EUS(NSA/SA +WiFi6E) or MR6550-100APS (NSA/SA+mmWave+WiFi6E)
Ir you can take previous generation, M5, MR5200-100EUS (only supports NSA so far)
Message 9 of 14
A99Problems
Hello, can you please help me with a information ?
I got a Netgear M6 Pro, model  MR6450-100EUS , but I'm not getting 5G connection , I tried all the prepaid networks available in Romania .
Any idee why ? Or how to fix this ? It should be working right ?
Message 10 of 14
W1lliam
Virtuoso
@JohnPeng maybe there is something need to modify for NR5G at Romania
Please do check with the carrier for such prepaid sim card if
1. they can be used with hotspot
2. APN settings is done correctly  to enable the service
Message 11 of 14
A99Problems
@W1lliam
I did checked the APN , its the same as on my phone, and my phone it's showing 5G connection , APN good everything good but no 5G connection on my Netgear M6 Pro device .. strange right ? What could that be ?
Message 12 of 14
W1lliam
Virtuoso
if APN has no issue, then you need to check if that sim card does support hotspot usage
Message 13 of 14
JohnPeng
NETGEAR Expert
Please send me a model.jsonf file with the SIM card inserted.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it back
You can send PM to me and mention your community ID.
Thanks
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 5457 views
  • 2 kudos
  • 6 in conversation
Announcements
Orbi 770 Series
