× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Nighthawk M6 Pro Unlocked Hotspot 5G mmWave
Reply
MR1100 does not broadcast wifi
b0rdga
hi guys
my hawk suddenly stoping broadcasting wifi i tried every singel idea come in any technation mind
- restarted
-reseted
- power off
- playing around with setting
but didnt work
after all i end up with i cant add any apn even with changing sim
any idea
Model: MR1100|Nighthawk LTE Mobile Hotspot Router (AU)
Message 1 of 15
Accepted Solutions
b0rdga
Re: MR1100 does not broadcast wifi
Thanks all for your advaices
I finaly fix it
just manual update it to 10.25.01.01
and im sorry for the bad spilling
you can download it from here
https://www.downloads.netgear.com/files/firmware/MR1100/MR1100-1TLAUS_23113199_NTG9x50C_10.25.01.01_...
Message 15 of 15
All Replies
b0rdga
BTW ITS UNLOCKED
Telstra
Message 2 of 15
MicW
Luminary
Does the dashboard or the wifi profiles shows that wifi is enabled and the "broadcast wifi name ssid" has a tick next to it on both the 2.4 and 5 ghz under settings>setup>wireless page?
Message 3 of 15
JasonN
NETGEAR Employee Retired
Hi b0rdga,
Have you tried removing and reseating the SIM card in the device?
Please let me know if this helps. :]
- Jason N
Message 4 of 15
b0rdga
Yes its look good without any problems in dashboard
And i had changed the SIM with more than 3 SIMs different company and also no APN & WIFI
Message 5 of 15
JasonN
Hi b0rdga,
Please contact support for further assistance on this issue.
Let me know the outcome please. :]
http://www.netgear.com/support/contact.aspx
- Jason N
Message 6 of 15
Chien35
Tutor
What is the current firmware version?
Message 7 of 15
JasonN
Hi Chien35,
What is your location? Which provider model is your MR1100?
Please let me know. :]
- Jason N
Message 8 of 15
Chien35
Tutor
Hi Jason,
My location is Cambodia and my MR1100 is Telstra.
Why you ask?
I don't have the problem.
Message 9 of 15
JasonN
Hi Chien35,
Sorry I thought you were directing the question to the community to be answered.
Hi b0rdga,
I wanted to check in on you and see if your issue was resolved with support?
- Jason N
Message 10 of 15
b0rdga
I had tried it and it gave me a disconnected phone no
Message 11 of 15
b0rdga
I had tried it and it gave me a disconnected phone number to contact
Message 12 of 15
JasonN
Hi b0rdga,
Did you follow the process of the link I have provided you? What support number did you use? Where are you located?
- Jason N
Message 13 of 15
JasonN
Hi b0rdga,
Please provide your location and what number you used to call support.
Thank you :]
- Jason N
Message 14 of 15
b0rdga
I finaly fix it
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 7957 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi 770 Series
