Orbi WiFi 7 RBE973
Reply
Can't create account to use Circle
mc510
Guide
Trying to get Circle going on my R7000. I enabled it on my router, then downloaded the Circle app on my Android device ... app says my router is compatible, I use the app to log in to my router account, it says "Circle is Enabled," then at "create account" it always says "can't connect to Circle." Anyone know how to get past this problem?
I'm on latest firmware V1.0.9.64_10.2.64
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 8
DexterJB
NETGEAR Moderator
Re: Can't create account to use Circle
Hi @mc510, welcome to the community! If you've just recently updated the firmware of the device, please try doing a factory reset as described here and see if that fixes it. Let me know how that goes.
Dexter
Message 2 of 8
DexterJB
NETGEAR Moderator
Hi @mc510, were you able to get this sorted out?
Dexter
Message 3 of 8
mc510
Guide
Hi again, sorry it took me a while to find the time to do the reset/reconfigure. I did it yesterday, but am still having the same problem with the Circle app (Android) saying that it can't connect to Circle.
Message 4 of 8
DexterJB
NETGEAR Moderator
Hi @mc510, please enable your Private Messaging since I will send you a message. Thanks!
Dexter
Message 5 of 8
mc510
Guide
I’m feeling kind of stupid here, but I can’t find where I am supposed to enable private messages. (Currently using iOS Safari mobile browser, if that matters)
Message 6 of 8
DexterJB
NETGEAR Moderator
Hi @mc510, you can click on your profile and go to My Settings > Preferences > Private Messenger > Check Turn on private messages.
Dexter
Message 7 of 8
mc510
Guide
found it. PM now activated.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2288 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
