Reply
Circle seems to have broken my network
rich1231
I setup enabled circle earlier after updating my Router. Installed the app, connected app to the router and configured a few devices.   Devices with no filters attached which were set to unmanaged, all lost internet connectivity... Well... they could connect to internet but could not access the desired services.. Smart TV could not access netflix, amazon echo would acknowledge commands but do nothing.  Amazon Fire TV says there is a network issue but on a connection, test says all is fine....    Same symptoms after disabling circle.   Same result after downgrading firmware. Same result after factory reset and restoring config.
Have tried rebooting all infrastructure on network but nothing has changed.   Laptop seems to be accessing all sites fine though.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 4
Accepted Solutions
TerryPh
Virtuoso
Re: Circle seems to have broken my network
Hi.
If you still able to get to router interface, flash it back to v.1.0.3.54 for now. And then do hard reset the router. This should help you get stable router function (but no Circle application for this version, only DDNS parental control ). Netgear is debugging firmware and hopefully they will get new update stable firmware soon. When? I do not know for sure.
Terry
Message 2 of 4
All Replies
TerryPh
Virtuoso
Hi.
Terry
Message 2 of 4
rich1231
Thanks that did the trick.  I had tried to restore a slight younger firmware but the issue remained..
I am assuming that once activated Circle's ARP Spoofing stays in place even after disabling on the router. Which is really terrible.
Message 3 of 4
SarveshMurthi
I rollback the Firmware Version V1.0.3.54_1.1.37 and monitored for 1hr still same unidentified device appearing in random.
I monitored for 3hr at random and found more than ten unidentified device appearing in random and I captured some of the devices hose list is below.
SL
Manufacturer
Model
Model Number
MAC address
1
INTEX
Aqua Power+
Aqua Power+
3C.97.0F.53.E6.15
2
LENOVO
TAB 2 A10-70L
TAB 2 A10-70L
98.0C.A5.C8.5E.DF
3
LENOVO
A7010a48
A7010a48
98.0C.A5.B9.D3.9F
4
COOLPAD
CP8298_I00
CP8298_I00
D0.37.42.C3.C2.51
5
IBALL
D7061
D7061
40.20.00.28.42.30
6
PANASONIC
P55 Novo
P55 Novo
70.0B.C0.92.96.A2
7
TCL
6042D
6042D
D8.E5.6D.CB.36.4F
8
LAVA
A3_mini
A3_mini
48.FC.B6.73.66.C0
9
VIVO
1609
1609
BC.2F.3D.2E.7E.4A
10
HTC
Desire 728 Dual Sim
Desire 728 Dual Sim
04.E2.3E.3F.04.0F
11
ASUS
ASUS_T00J
ASUS_T00J
08.62.66.07.02.D0
12
MOTOROLA
XT1663
XT1663
48.88.CA.24.42.FE
3C.97.0F.53.E6.15.jpg08.62.66.07.02.D0.jpg40.20.00.28.42.30.jpg48.88.CA.24.42.FE.jpg48.FC.B6.73.66.C0.jpg70.0B.C0.92.96.A2.jpg98.0C.A5.C8.5E.DF.jpgD8.E5.6D.CB.36.4F.jpg
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 4285 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
