Orbi WiFi 7 RBE973
Reply
Orbi with RBR50 bedtime not ending
joergn
Hi there,
I have an Orbi RBR50 with an RBS satellite. Setting "Bedtime" for my kids work once at entering bed time. Next morning (after bedtime end was setup) my kids complain Orbi still shows "bedtime". We are in timezone Berlin. This has never worked. What do you recommend?
Thanks,
Jörg
Model: RBR50|Orbi AC3000 Tri-band WiFi Router
Message 1 of 5
Guru
Re: Orbi with RBR50 bedtime not ending
Where are you configuring this "bedtime" schedule?
Is the time zone set feature correctly for your region?
Message 2 of 5
joergn
Hi, I was not precise. I use Circle App-Version 2.1.12 (873) with Firmware 2.3.0.1 on an Orbi RBR Firmware V2.7.3.22. I define „Sleep Time“ on Circle app on iPhone/iPad.
Message 3 of 5
Guru
Netgear has set up a community forum specifically for the Circle product. Most of the people who watch that forum are more likely to have experience with Circle and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Circle-Smart-Parental-Controls/bd-p/en-home-circle
Thank you.
Message 4 of 5
Guru
Any progress on this?
Message 5 of 5
Discussion stats
  • 4 replies
  • 1820 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
