Orbi WiFi 7 RBE973
Reply
RBR20 After Firmware Update - Circle can't be enabled
awinskill
Follower
After upgrading to Router Firmware Version V2.6.2.104 I am unable to access Circle. I've tried reversing the firmware upgrade but I still can't access circle. I can enable Circle via the Orbi app (iOS) but when the Circle app starts it tries to Enable Circle and gets stuck in a loop (keeps coming back to the same "Enable Circle" screen).
Model: RBR20|Orbi AC2200 Tri-band WiFi Router
Message 1 of 4
Guru
Re: RBR20 After Firmware Update - Circle can't be enabled
Did you look under Basic tab menu list for Parental Controls?
Try a factory reset and set up from scratch?
Try this? https://community.netgear.com/t5/Circle-Smart-Parental-Controls/Missing-parental-controls-on-firmwar...
Message 2 of 4
Retired_Member
Not applicable
Did you find a resolution? Please share if you did.
@Christian_R  can you help resolve this issue???
Message 3 of 4
Retired_Member
Not applicable
I had to go back to previous firmware version fyi. Netgear is worthless
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1281 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
