- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can't connect to Sony Bravia TV
- Mark as New
- Bookmark
- Subscribe
- Permalink
We have a Bravia TV KDL-46HX800 and a UWA-BR100 USB wireless LAN adapter. We can't connect to the internet. It is showing that it has found the network but doesn't connect. I have tried everything suggested including using a network cable instead but still won't connect. The modem is a Netgear N300 DGN 2200. Has anyone had success with this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Can't connect to Sony Bravia TV
If you have tried wifi and LAN (always the best option) then the problem probably lies in the smart TV.
You are not the first person to turn up here with similar problems. These things can be beasts to set up. Sadly, you will probably have to pursue this with the Sony experts.
I use a Samsung smart device and that requires messing around with its network configuration. All the Netgear device does is spit out the Internet.
Check these Search results for earlier discussions of similar problems.
If your Bravia offers WPS as a way to connect, try that, but if possible use wired. I have a powerline network for mine.
