- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D3600 - problem connecting to BT - BT wholesale error
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, I have a v old netgear router which works fine on my BT copper line before and since.....tried installing the D3600 and got an error message from..... BT Wholesale ...."your service provider is currently unable to accept your connection request........" Has anyone seen that? Thanks Andy
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D3600 - problem connecting to BT - BT wholesale error
Do you mean the BT Wholesale speed test?
In other words, what are you trying to do when you connect?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, thanks.....no there is simply no internet connection and an error message from BT Wholesale.....I assume the settings are wrong on my new router
- Mark as New
- Bookmark
- Subscribe
- Permalink
So you are a customer of BT Wholesale?
My modem does not offer this as an option in the setup pages for DSL. I see just BT.
Are you using the wizard for setup, or manually putting in details?
Which BT service do you have ADSL? Infinity?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi....I am a BT copper ADSL customer......the error message is simply from BT Wholesale.....as per this link....https://community.bt.com/t5/BT-Infinity-Speed-Connection/All-pages-redirecting-to-62-6-38-125-index-.... My old router works fine - therefore I am assuming it is a settings issue on the new one
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am also on BT copper. But my DSL is Infinity.
The link you gave to the BT Forum was also about Inifinity. Is that what you have? You did not answer when I asked before. "BT copper ADSL" could also refer to BT Infinity.
Nor did you answer when I asked, if you are using the wizard for setup, or manually putting in details?
If the old router still works, go in and note down the settings for your internet sign in. Then find the places to insert those details for the D3600.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi thanks. I have been using the wizard. Broadband is the basic copper service. Not infinity
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK. The wizard clearly has lost its magic, so you'll have to feed in the information manually.
Look at page 44 of the manual for the D3600. (It is on the support pages for the device.)
The information you have to provide is on page 48.
As I suggested in my last message, you may be able to get the information you need from your old manual, or you can probably find it on the BT support pages. I don't have BT's ADSL any more now that I have switched to Infinity DSL.
This message, for example, gives some of the details:
What is my BT broadband username and password? - BTCare Community Forums
There are more where that come from.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for being so helpful - will give it a go this evening
